DIY cruise control retrofit
Hey guys.
I'd like to put cruise control on my e60 2006 and on some forums i found that i need to change dashboard in some cases, but it didn't know how to be sure do i need it or not.
Search in the Google show me some topics form Spain with some discussions but i didnt understan? them at all. Use google translator but its still worse.
Has anybody any ideas? Any links will be appreciated.
My Ride: BMW 525I E60 01/2004
Hey guys.
I'm almost sure you won't need to change the dashboard.
You will need to buy the cruise control stalk and maybe a few other parts and do some coding.
Best regards
Some photos.
To make sure if you want change the dashboard or not you need to make test number 2 to see if you have cruise-control pointer going round speedometer.
http://www.youtube.com/watch?v=SwFi64rmOKI&feature=player_embedded
After that i've made complete upgrade of car sw and some coding and cruise starts working
http://www.youtube.com/watch?v=fD9HuXP8Oc4&feature=player_embedded
Hi Rostman,
I´m from Germany and want to retrofit the Cruise control to.
I have no dahshboard with the circling Point around the speedometer.
Need I a new dashboard or is it still possible to code the cruise control?
Thx
p.s. if heard that it gaves a trick to do it.
Thx
i have coded the $541 but i have no function of my cruise control szl.
Can you tell me what i have to do? Need I a new dashboard?
I´ve a spanish BMW car without cruise control before i have retrofit it.
My Ride: BMW E60 528i
Hi~ Rostman & E60-Gaser
I'm doing the same retrofit of cruise control on my E60 528 2008.
I have ordered the following parts.
1) CRUISE CONTROL SWITCH 03/2007~ 6 131 695 1352
2) Front section of trim panel 12/2003~ 6 131 694 7773
Are there any other parts I should order?
And while coding SA 540A option, no error message during coding? like steering wheel calibration.
Please help me. THANKS
E60-Gaser: I think the correct SA code should be S540A not S541A(Active Cruise control).
Hello,
are there any news about the topic. I want to retrofit, but haven't the cycling point around my speedometer.
Can I retrofit my cruise control without a new combi instrument / dashboard?
Actually nothing works. Installation of the szl and coding is done.
Thanks in advantage for your replies.
E60-Gaser
E60-Gaser
I'm also interesting...
So far, the new kombi is necessary. My current one has no speed pointer.
I'm looking for the trick without exchanging old kombi as mentioned above.
