Bluetooth Entry
Old 03-16-2015, 01:35 PM
juji126's Avatar
My Ride: 2007 530xi
Default Bluetooth Entry
Any takers..
Unlock Car with Cell Phone Passive Keyless Entry PKE Smartphone | eBay
I'd give it a try but i'll need someone to tell me where I can find the positive pulse wires for LOCK and Unlock. Also what colors they are..
This would compliment my FLrsBM1 remote start very nicely
Old 03-16-2015, 01:44 PM
juji126's Avatar
My Ride: 2007 530xi
Default Here the module diagram
7-Pin Main Harness (White Connector)
Pin 1: RED +12V Battery input, must be continuous. It is recommended to place a 1
amp fuse (not included) to protect the vehicle in the event of a short.
Pin 2: BLACK Ground input, must be connected to solid chassis ground. If a data bus
module is being installed, it is recommended to share the same ground between the data
bus module and the BPKE module.
Pin 3: PINK +12V ignition input, wire must have +12V when ignition is on.
Pin 4: GREEN Lock output, negative output up to 250mA for 0.8 seconds when Lock
command is sent from Companion App to BPKE module. !!This wire rest at positive!!
Pin 5: BLUE Unlock output, negative output up to 250mA for 0.8 seconds when Unlock
Pin 6 & 7: EMPTY Do NOT connect to these pin locations, you WILL cause damage!
2-Pin Programming Switch (Blue Connector)
Mount the programming switch in a location that is accessible.
2-Pin Status LED (RED Connector)
The LED can be removed from the housing for more mounting options.
Old 03-16-2015, 01:45 PM
juji126's Avatar
My Ride: 2007 530xi
PIN 4 and PIN 5 are the ones in question
Old 03-16-2015, 01:48 PM
juji126's Avatar
My Ride: 2007 530xi
Important Information regarding the BPKE module's outputs
The outputs of the BKPE module can be used only to trigger lock/unlock
functions, DO NOT attempt to power lock/unlock motors directly from the
outputs of the module. It is helpful to use a databus module on modern
vehicles to control the lock/unlock and factory arm/disarm whenever there is
one available for the vehicle. Door Lock Relay modules can also be used in
place of a databus module.
Old 03-18-2015, 01:24 PM
juji126's Avatar
My Ride: 2007 530xi
Default Passive Keyless Entry
Dei 2102T Passive Keyless Entry System Viper Python Clifford PKE Keyless Entry | eBay
Maybe this would be a better choice...
Old 03-21-2015, 09:23 AM
xonreh's Avatar
I am also planning to add a module to control remote starting & lock/unlock from my cell phone. Since Directed lists Smartstart as being compatible with the FLRSBM1, I checked the Viper website and was planning to add a VSM200 module (Viper SmartStart Module) to my car. I've been hesitant because the VSM200 module can only be activated by an authorized dealer. Some dealers are advertising activation service for $25 on eBay. I'd then have to purchase a service plan through Viper (Viper SmartStart Service Plans). Total cost: $90 VSM200 + $25 Activation + $140 3 yr service plan. I'm still researching to confirm no compatibility issues. Installation instructions: http://www.directed.com/SmartStart/D...010-08_web.pdf
Old 03-23-2015, 04:20 PM
juji126's Avatar
My Ride: 2007 530xi
Default smart start
I just talked with viper... apparently the module uses 2G network. Don't use it. 2G is almost non-existent. Sorry pal
Old 03-23-2015, 04:22 PM
juji126's Avatar
My Ride: 2007 530xi
Default entry
I'm gonna try to go with the PKE2102T. I'm calling up a few places in NYC to see if they can install it.
Old 03-23-2015, 08:09 PM
xonreh's Avatar
After viewing multiple Viper Smartstart youtube videos, signal speed was no more than a few seconds. On Viper's website, the following is posted: Viper SmartStart works over the 3G cellular network or over Wi-Fi, giving you virtually unlimited range anywhere in the U.S. As long as your vehicle is in range of a GSM cellular signal and your phone has a 3G or Wi-Fi signal, SmartStart will work (Viper SmartStart FAQ). I bought a new module for $80. I'll know in a week or so if the purchase was worth it.
Old 03-24-2015, 10:31 AM
Boost7's Avatar
My Ride: E60
Model Year: 2005
interesting, will it be able to arm/disarm the factory alarm at the same time?
Quick Reply: Bluetooth Entry
