Clear Coat On Grill always Go within months
Old 07-08-2013, 08:53 AM
hks
hks's Avatar
My Ride: E60 550i Sport
Default Clear Coat On Grill always Go within months
Im having a problem i cant get around. Ive been through several carbon fibre grill and within 6 months they turn yellow. The last grill i ordered i made sure add an additional three coat of clear and it was the same problem. I know the 550i gives off serious heat but is anyone else having this problem?
Old 07-16-2013, 09:59 AM
hks
hks's Avatar
Old 07-17-2013, 02:04 AM
tonyb635's Avatar
Who is applying the clear? I know if cheap inexpensive clear is used, it will turn yellow over time and certain conditions can also accelerate this. Often it can be corrected if not allow to go beyond the Abyss, by wet sanding and re-applying clear. If your grill looks better when you get them wet this is normally a good sign that a new clear could improve it. If this is your situation I would give them a good wet sanding with 800 -1000 g paper and go by you local body shop and see if they can spray them for you.
kammy6000
07-02-2015 05:05 AM
gurp99
07-01-2015 05:05 PM
umichchris
14
06-23-2015 03:36 PM
Tru5g
05-19-2015 07:46 PM
biker1bmw
04-05-2015 07:44 AM
Quick Reply: Clear Coat On Grill always Go within months
