2008 Xdrive Mechtronics sleeve replacement
Old 03-16-2019, 05:22 PM
rsewell's Avatar
My Ride: 2008 528xi
Default 2008 Xdrive Mechtronics sleeve replacement
Hello All,
First time poster here. I'm in the process of replacing my mechatronics sleeve in my 2008 528xi. I have already removed the old sleeve from the transmission on the heat shield side, however I am having a really hard time getting the new sleeve between the transmission mount and the transmission without damaging it. Can anyone please offer some guidance. Do I need to remove the heatshield and trasmission mount? Thanks.
Old 03-17-2019, 12:38 PM
rsewell's Avatar
My Ride: 2008 528xi
I got it figured out, I was able to put a pry bar between the trans mount and the transmission and was able to pry it over just enough to slip the new sleeve past the edge of the housing. It was a very tight fit, however it did end up going. Hopefully anyone else in the future that has this problem can use this solution to get their part up into place.
Old 03-29-2019, 07:58 PM
SMOKESHOWIN1's Avatar
My Ride: 2008 535xi Monaco blue metallic/beige sport options
Thanks for the info.
Old 09-07-2023, 04:02 PM
Probation Members
Nick40c's Avatar
My Ride: 2008 528XI AWD
Default Tight fit! Bad design......
Where did you place the pry bar? I've got my sleeve out of the trans, but not through that small gap between transfer case and trans body.
Old 09-17-2023, 09:01 PM
Probation Members
Montanamatt's Avatar
My Ride: 2007 530xi
I just did mine on my 07 530xi. I dropped the heat sheild and then removed the 6 bolts holding the xfer case. I supported it with a jack and lowered it a little bit and had plenty of room to remove and replace. Good luck!
joge
01-16-2021 12:01 AM
Dvirg10
08-31-2018 06:40 AM
wabbastang
09-13-2017 08:45 AM
Booyaazaa
05-14-2015 12:45 PM
Only Bimmers
08-14-2012 12:14 PM
Quick Reply: 2008 Xdrive Mechtronics sleeve replacement
