Transmission fault 08 535
#22
My Ride: 535i
those are my codes :
507B PARKING GEAR SENSOR IMPLAUSIBLE
4F81 RATIO MONITORING CLUTCH A
4F84 RATIO MONITORING CLUTCH D
4F97 RATIO MONITORING CLUTCH "B"-D
PLS CHIME IN GUYS
TONY YOU GOT JUST ONE CODE ?ARE THESE CODES REFERRING TO SAME ISSUE ? DOES NOT GO IN REAR ANY MORE
CAR AT THE SHOP ….. DOES NOT WANT TO GET DISAPPOINTED IN BIMMER .
PLS CHIME IN GUYS
#23
All I had was the one code and Car is back in order now. The sealing pressure block and sleeve was replaced. The block had a crack so just as the video showed the pressure is limited. Also I had the older level sleeve so this was also replaced
#26
BTW I'm sitting up here in somersworth at Conti, you guys still have a crap load of snow up here!
#27
My Ride: E60
Model Year: 2005
tony - glad to hear you go the transmission fix without paying a huge amount
I hope to get my transmission problem fix soon too.
#29
My Ride: 08 535i
PLS CHIME IN GUYS
PLS CHIME IN GUYS
#30
My Ride: l
PLS CHIME IN GUYS
PLS CHIME IN GUYS
