Thinking about pulling the trigger on Dinan Stage II ...
It seems there was a permanent price drop of the Dinan Stage II for the 535's. It's now holding steady at $1799. According to Dinan it will no longer go on sale for 20% off (at least not for a while). You can probably get it a little bit cheaper if you finagle it with the dealer/installer (to get closer to ~1750-1760 price at least). Question to anyone that's purchased it... have you got this for a good deal cheaper or is this about what you paid (assuming 20% off sale from the former $2199 price)?
I've never heard anything bad about the Dinan ECU flashes other than price. It's obviously a lot more expensive than the JB3/JB4, Cobb AccessPORT, and a few others, but I have a ton of warranty left on my car and really want that piece of mind that comes with the Dinan flash. It seems they put in a lot of time engineering their solution so it puts out a lot of performance and really shouldn't ever cause anything to go wrong with your car.. and if it does they will take care of it as long as you're within their warranty constraints.
With that said and my reasoning does anyone see a reason not to go with the Dinan Stage II? Is there some sort of other solution now that will do a matching warranty type deal?
Overpriced for the amount of HP/Torque you receive, if you want a better tune that you can remove/reinstall through your obdII then I would just wait for the new version of the Cobb to come out. Supposedly it is going to blow any other tune available at the moment away and there has been nothing but great comments and remarks about it on the e90 forums.
My Ride: Car
No doubt there's Cobb, JB4, etc, that have higher gains and are more customizable and less expensive than Dinan, but your warranty goes out the window with them. For my decision, the most important factor was warranty coverage 1st, performance 2nd, and price 3rd. The only way to maintain warranty was to go with Dinan so factors 2 & 3 didn't matter. Sure there is some performance sacrifice but coupled with an exhaust & scoops, I can still reach a nearly 400hp level or so. Given that my car was a new purchase with its entire warranty available I went with Dinan based on my needs. Had I bought a used car less perhaps the decision would have been different. They are all great tuners, over-rated or not, and all provide an amazing driving experience.
The only way I see someone getting caught with one of these tunes if they are bright enough to put a sticker in their engine bay saying JB4 performance.
Or you actually blow out a turbo/key part of your car. That will result in them doing some hard core research as to why it happened and they'll likely find some sort of data to support an add-on that modified boost/other stuff in the vehicle. You're also committing warranty fraud when you do that, which may not be that big of a deal.. but something else to keep in mind.
My Ride: Car
The dealer by my house is not a Dinan shop. I blew a bank of injectors. The local dealer wanted to charge me thousands for all sorts of new parts, diagnostic fee, it was insane. When I questioned them they said while there were no codes, they ran a torque map and saw it was flashed. I immediately limped my car to the Dinan-authorized BMW dealer and they handled it under warranty. Sure you can clear codes and the like, but dealers now resort to different tactics to investigate.
My Ride: 08 535xiT - Sapphire Black / Beige
As someone who owns a Cobb [Persian, they're coming out with a new one?] and loves it, if I bought my car new, I would have gone with the Dinan. For about $1k, give or take, its insurance & piece of mind in case anything happens with these damn tempermental turbo engines.
Corey - did you dealer ever give any reason why the a whole bank of injectors went, kinda scary. None of the out of the tunes really stress the engine to levels that should blow anything. Also, you mentioned a scoop, do you have an RPI? Do you feel it makes a noticable difference? Says it makes an additional 7hp or something at 65mpg...
