Steaming engine but no overheat
#21
My Ride: 2010 535i xdrive
Model Year: 2010
Could also be coolant. Recently saw the steam you are talking about, brushed it off, got the low coolant light. Topped off the coolant a few days ago, low coolant light came back yesterday. Traced the coolant line and small leak found by a clip.
#22
Well, did some dissassembly yesterday. Radiator has a hole down near the lower hose connection on the passenger side. Not a big hole, but a hole.
Since I'm not working right now and have the time, I'm going to do the replacement myself along with replacing the water pump and thermostat. (Oh joy...). I purchased the pump and thermostat a few years ago from ECS (OEM parts) so at least I don't have to buy them now. Funny thing: all the comments on WP replacement say you need 3 new aluminium bolts. ECS supplied new bolts but they're steel. WTF?
Also, while removing the top cover from the radiator, the hose that goes from the expansion tank and across to the upper rad hose snapped when I tried to gently unclip it from the housing. The plastic pipe is so brittle I can break it like a strand of dry pasta. Rather than buy an entire new hose, I'm thinking I can just replace the 1 foot long plastic bit in the middle - suggestions on material? I have some copper tubing that would fit...
Stealer wants C$784 for a rad. Aftermarket rad is C$380. Behr OEM is the same price as stealer from my local parts place. I hate putting non-OEM bits on my BMW, but C$400 is a lot of dollars for that ethic.
#23
My Ride: 05 530i
I am glad that you found your problem.
#24
Salut, Bob P.
#25
Who is your supplier? I can contact to see if shipping is reasonable. I'd prefer not to put some generic "made in the far-East" stuff in my car, even though it's 9 years old and has almost 200,000km on it.
#26
True on the copper. I'll look for some aluminum tubing. They could have made the whole hose from EPDM, but no...
#27
For anybody reading this, the Bentley manual is wrong about taking the electric fan assembly off. No mention of a nearly inaccessible bolt holding a hose bracket, nor any mention of removing an even more inaccessible strap tie holding a hose just below the upper radiatior connector, nor a tie strap at the bottom, nor a couple of other hose clips.
What else are they wrong about? Probably lots of stuff.
Now, on removal of the upper hose by the oil filter, the o-ring and retainer bit from the hose end stayed on the nipple instead of staying with the hose. I suppose this means I need a new upper hose too?
