Steaming engine but no overheat
2008 535xi.
I was waiting in the gas line at Costo the other day and had been idling for a few minutes. You know how long Costco gas lines can be, but heck, if I can save $10 on a tank I'll spend a few minutes.
It's a bit below freezing and all the cars around are spitting steam out the exhaust as usual, but I suddenly noticed there was steam coming out of my grille. Opened the hood and there was a fair amount of steam in the engine bay. Cooling fan was cycling normally. I shut off the engine and waited until I could pull up to the pumps.
After filling, re-started and the steam was still coming out. I pulled across the parking lot and called AMA for a tow.
Got the car home and by that time the engine was cool so I checked and the coolant reservoir was full. Idled it for 15 minutes or more in the garage and no steam. No wetness anywhere I can see either.
Yes, the roads were wet/slushy, but I don't think I picked up anything that was melting/steaming on a hot engine.
Time to take it for another drive and see if it repeats.
My Ride: 2005 545
2008 535xi.
Have you ever seen a football player with a hot and sweaty bald head remove his helmet in really cold temperatures ? Steam will rise off his head ..
My Ride: 2005 545
Kind of ironic having a Californian telling an Albertan about winter or cold weather phenomenon.
My Ride: 2005 545
The dew point of the air would have to be at 0 degrees also (i.e snowing). Air moisture will not condense on the hot fins and cause steam, but snow or freezing rain might, OP stated that it was just below 0. and not precipitating. I suspect some built up snow in the cabin air filter area melting dripping off the hot engine or exhausts,
What happens when you blow warm air out of you're lungs and that warm breath of air hits the super cold weather ?? Same principle .
This is not a extraordinary phenomenon ,, there is plenty of information of this happening in cold weather,, with out rain and snow . And you don't exactly have to be a Albertan or a eskimo to know or read about it .
Doesn't have to go as far for moisture to condense and settle on the fins . The cold humidity and moisture in the air just has to hit the hot fins and it can happen .. Moisture in the air does not condense on the hot fins, it is simply heated and actually if the moisture was visible (fog) it disappears.
What happens when you blow warm air out of you're lungs and that warm breath of air hits the super cold weather ?? Same principle .No not exactly. The warm humid air from your breath condenses in the atmosphere, so you can see it.
With respect, Bob P.
My Ride: BMW 545i 2005
H F is giving you the scientific approach or in Laymans (sp?) terms real life diagnosis to the steam coming from the engine and some of you are are trying to suggest he is wrong....Read what he has to say and apply it to whats happening......I dont understand why the attack on HF.... HF, I'm with you. Thanks for the clarity and taking the time to respond.
