Seat mat sensor canada recall
Old 04-10-2012, 01:34 PM
mullenc525's Avatar
My Ride: 04 545i 6spd m/t Sport, Cold Weather, Logic 7
I'm getting the run around by BMW and not sure where to go next. I called in a month or two ago and was told this is a recall issue on my VIN and that if the error was related to the seat mat sensor it would be fixed free of charge. Today I call in to book an appointment and I am told it is not a recall issue by both BMW of canada and the local dealer.
I know other members have had this issue dealt with under recall. I know it is VIN based but it seems everyone with sport seats from several years but definitely 2004 was included. What's my next move?
Old 04-11-2012, 02:13 PM
Shlooky's Avatar
My Ride: 545i
I have the same problem, called BMW Canada and they said my 545i is not covered (I have comfort seats)
Anyway I will look into it myself, will tear the seat apart if I have to, to find where the sensor sits and see if I can replace it myself.
Old 04-11-2012, 06:54 PM
mullenc525's Avatar
I'm waiting for transport canada to return my call... its horse shit, of course its the same issue as was recalled on the other models.
Old 04-12-2012, 11:10 AM
mullenc525's Avatar
Wow transport canada actually returned my call and worked out the issue within 24 hours, I'm impressed
Turns out that while some VINs were not eligible for the proactive recall, they do still get the 10 year warranty. Inexperienced people at the BMW call center or dealer may not realize this and tell you that you have to pay for your seat mat sensor without realizing it is under warranty.
Old 04-12-2012, 08:40 PM
Shlooky's Avatar
My Ride: 545i
can you please post the number for transport Canada and what did you say to them so I can follow your process?
Many thanks for all your help!
Old 04-13-2012, 10:23 AM
mullenc525's Avatar
1-800-333-0510 (toll-free in Canada)
I spoke to a guy named Jean-guy (French Canadian pronunciation I believe)
Old 04-13-2012, 10:34 AM
stock545i's Avatar
My Ride: 545i, Adaptive Xenons, 19" 166's
Here is what the outcome ended up being in my case:
"The dealer found faults for safety battery switch. Tested and found to have high resistance. Replaced the battery cable (Part Number 61-12--7-835-218) and retested.
The part was $231.40
Labor was $371.
Use the BMWCCA club discount, or look up on the dealers website, incase they have a single job discount coupon.
I could have paid the dealer for the diagnosis and replaced the cable myself, but opted to pay a little more so they would replace this part and retest.
Good luck.
Old 04-14-2012, 09:01 AM
mullenc525's Avatar
All fixed, it was the seat mat. I was sure it was; I got the error immediately after installing my Dension gateway in the glovebox, so I'd been all over my passenger seat with knees and elbows which apparently is pretty tough on them.
Old 04-14-2012, 09:21 AM
healthservices's Avatar
So how much is this seat mat? DIY?
Old 04-14-2012, 11:00 AM
stock545i's Avatar
Here are details on the recall. Good luck with the mat replacement. It can be done. You have to disassemble the seat, remove upholstery to get to the mat.
If anything BMW Canada should provide the part, and you can request a goodwill repair at the dealer so you only have to pay for labor.
Again - only way they are going to confirm the issue is with your mat and not positive power source is by running the tests.
GL
RECALL: 2004-2006 BMW 5-Series
NHTSA Campaign Number: 08V384000
www.nhtsa.dot.gov
Manufacturer BMW OF NORTH AMERICA, LLC
Recall Date: JUL 18, 2008
Potential Number Of Units Affected: 200000
Description AIR BAGS:FRONTAL
Summary BMW IS RECALLING 200,000 MY 2006 3 SERIES SPORT SEAT, MY 2004-2006 5 SERIES STANDARD AND SPORT SEAT, AND MY 2004-2006 X3 PASSENGER VEHICLES. DEPENDING ON THE MANNER AND FREQUENCY OF THE FRONT PASSENGER'S ENTRY AND EXIT, SMALL CRACKS HAVE DEVELOPED IN THE MAT. IF THIS OCCURS, THE FRONT PASSENGER AIR BAGS, WITH THE EXCEPTION OF THE HEAD PROTECTION SYSTEM, WILL BE DEACTIVATED AND THE AIR BAG WARNING LAMP AS WELL AS THE PASSENGER AIR BAG "ON-OFF" LAMP WILL BE ILLUMINATED.
Consequence IN THIS SITUATION THE FRONT PASSENGER AIR BAGS WILL NOT DEPLOY EVEN IF A SUFFICIENTLY SEVERE ACCIDENT WOULD OCCUR AND OCCUPANT PROTECTION PROVIDED BY THE SYSTEM WOULD NOT BE POSSIBLE.
Remedy DEALERS WILL REWORK THE FRONT PASSENGER SEAT SENSOR MAT SO THAT EXTERNAL FORCE APPLICATION TO THE SEAT DOES NOT CAUSE A CRACK TO THE MAT. THE RECALL IS EXPECTED TO BEGIN DURING LATE SEPTEMBER 2008. BMW WILL ALSO EXTEND THE WARRANTY ON THESE VEHICLES TO 10 YEARS FROM FIRST REGISTRATION WITHOUT ANY MILEAGE LIMIT.
HERE IS THE SIB:
SI B 65 75 06
Audio, Navigation, Monitors, Alarms, SRS
April 2009
Technical Service
This Service Information bulletin supersedes SI B65 75 06 dated February 2009.
[NEW] designates changes to this revision
SUBJECT
Airbag Warning Lamp for OC3 Seat Mat Fault
MODEL
E53 (X5) vehicles produced up to 11/2005
E60, E61 (5 Series) vehicles produced up to 11/2005
E63, E64 (6 Series) vehicles produced up to 11/2005
E65, E66 (7 Series) vehicles produced [NEW] up to 11/2005
E83 (X3) vehicles produced up to 07/2006
E85 (Z4) vehicles produced up to 11/2005
___________________________________
E90, E91 (3 Series) vehicles produced up to 11/2005
Only vehicles where the OC3 mat has not been replaced with the later version
SITUATION
The customer complains that the Airbag Warning Lamp (AWL) is illuminated, together with the Passenger Airbag Status Lamp (POL). The problem may be intermittent.
Depending on the vehicle concerned, one of the following OC3 seat mat faults is stored in the SRS Control Module/Satellite 95B8, 71, 93C3, 97E0.
In the interest of customer satisfaction, the warranty coverage of the vehicle for this specific airbag warning lamp issue has been extended to 10 years without mileage limit. The letter has been sent to the owners of all affected vehicles to advise of this change. Eligible vehicles will be shown in the DCS Warranty Vehicle Enquiry (see attachment).
[NEW] Note that on E65 and E66 vehicles, the OC3 mat was introduced from 03/2004. Earlier vehicles had an SBE seat occupancy detection system. However, letters were mistakenly sent to owners of all vehicles up to 11/2005. Therefore BMW will honor this extended warranty for seat mat defects on the
passenger SBE mat.
CAUSE
Microcracks in the OC3 seat mat.
CORRECTION
On a customer complaint basis only:
Follow DIS test plan.
If no other faults are found, replace the OC3 seat mat.
Note that replacement parts for some vehicles are supplied without the cover material (foam pad with integrated OC3 mat). In this case, remove the cover from the faulty seat and reinstall on the replacement
part per RA 52 13 400.
NOTE : To avoid the possibility of a preload condition on the assembled part, be sure to follow the repair instructions. The OC3 mat will not enable if there is preload.
[NEW] For E65 and E66 with the SBE mat, refer to Repair Instruction REP 65 77 598 to replace the SBE seat mat. No programming is required.
Quick Reply: Seat mat sensor canada recall
