Retrofitting electric folding mirrors on the E60 - coding advice?
Old 04-12-2015, 02:24 PM
Stormcrow's Avatar
My Ride: 530D M Sport [Pre LCI]
Default Retrofitting electric folding mirrors on the E60 - coding advice?
Hello,
Could you please help me with coding for automatic electric mirrors?
I have a PRE LCI (2005) e60 530d M Sport - this car has the diamond key. It does not have push button start. I am currently in the process of upgrading the mirrors to electric folding. The car had electric glass and heated mirrors. The mirrors were connected with multiple wires and one plug to a module in the door card.
I have purchased new electric folding mirrors, they have multiples wires and two plugs. I took apart the door card and retrofitted the new mirrors. The two plugs were connected to the module in the door card.
Coding - I have verified that the coding has taken place by reading the module files again. Please see attached the trace files.
I added $430 to the VO in both CAS and LMA.
I checked the CAS module has the comfort options active:
  • KOMFORTOEFFNUNG >> aktiv
  • KOMFORTSCHLIESSUNG >> aktiv
I updated the two door modules: TMBT and TMFT. I made the following changes:
  • KERBING - changed from nicht_aktiv to aktiv
  • FOLDING - changed from nicht_aktiv to aktiv
  • BEIKLAPPEN_B_KOMFORTSCHL - changed from nicht_aktiv to aktiv
The mirrors still do not fold using by holding the lock button. (The windows go down when I hold the unlock button. The windows also go up when I hold the up button).
Does anyone know what I am doing wrong? Could you please let me know if I need to make any further changes?
File Type: txt
File Type: txt
File Type: txt
Old 04-13-2015, 04:07 AM
wcr3d's Avatar
My Ride: 2006 530xi w/Sport, Premium, Cold weather. Silver Gray Metallic, Black Dakota leather interior.
This may help some...
https://5series.net/forums/e60-discu...trofit-111157/
Old 04-13-2015, 04:20 AM
Stormcrow's Avatar
Originally Posted by wcr3d
Thanks for this, I have gone through all the existing threads on various forums and not found the answer to the coding....
Old 02-07-2017, 03:32 PM
gabon3zu's Avatar
My Ride: BMW 530d M Sport 2008
Hi mate.. I have an e60 530d LCI 08 so mine it's a bit newer but with standard electric auto dimming mirrors and I want to upgrade them to auto folding mirrors, anyway.. I found the mirrors + loom + door control panel for them.. But I don't know to fit them.
I see you done similar work on yours some time ago and u was very happy with the upgrade..
By any chance do u still have the email or phone number from the guy who has done yours or do u know anyone ?
Appreciate your help mate and thank you for your time..
Old 03-12-2017, 11:31 AM
ZebraBrains's Avatar
My Ride: E60 2005 545i Sport Black Sapphire Shadowline Trim 18" Style 124 Staggered Rims LM2 Upgrade
Model Year: 2005
Has anyone figured out how to code this correctly for a pre 9/2005 with door modules?
Old 08-03-2019, 08:19 PM
Gondar2009's Avatar
My Ride: 2009 528i Stock
Auto folding must have the option installed else will not work. Check the little button next to side view mirror select slider. If you can fold the mirror by pushing on the little push button, then you have that option installed. You can code it else no Joy.
Old 10-09-2019, 05:12 AM
Виктор Ðики's Avatar
My Ride: Bmw 535d lci e60 2008
Hey mate. What kind of loom have you used and where I can get it?
Old 10-12-2019, 11:17 PM
Rvn10's Avatar
My Ride: E60 530xd
I believe with his car already being equipped with Auto dimming mirrors, the wiring was all there, only had to plug new mirrors and do a bit of coding.
Old 12-01-2019, 02:09 AM
ollyd's Avatar
My Ride: E61 530d Auto 2004
Default Completed auto dimming and folding pre LCI mirrors
Just finished installing folding and dimming. Any pre LCI mirror with a yellow wire has folding function. Sellers on ebay seem not to realise and this enabled me to get mirrors for less than £40 each. The folding mirror switch is not needed but mine cost a tenner so worth having when squeezing through gaps.To get the dimming mirrors working you need an auto dimming rear view mirror. This is an easy retro fit. You take pins 4+5 to drivers mirror wires and pins 6+7 to the passengers. On LCI cars only pins 4+5 are used to feed a central module. There is plenty written on the internet on how to code these features already. To get the passenger mirror to dip you need a memory seat module. Im going with full comfort seat retrofit which Im in process of sourcing now.
530D Lee
119
11-25-2017 06:35 AM
IMTx
03-13-2013 08:43 AM
bruce_miranda
11-08-2012 11:36 AM
Rizzy535d
DIY: Do It Yourself
06-29-2011 01:31 AM
sputnik
04-22-2010 01:53 PM
Quick Reply: Retrofitting electric folding mirrors on the E60 - coding advice?
