QUAD PROJECTOR RETROFIT ON MY E61: A few photos
Old 10-01-2014, 07:37 PM
ucsbwsr's Avatar
My Ride: E61 with all the mods
Engine: N54
Default QUAD PROJECTOR RETROFIT ON MY E61: A few photos
I couldn't resist cracking open my headlights, the oem angel eyes and projector performance leaves much room for improvement. After ordering a set of Mini H1 (MH1) projectors for a retrofit in my girlfriends Prius, I decided to order a pair for myself and stuff them into the housing for my angel eyes and cornering light, which we both know are useless.
The project was a lot of work but also a lot of reward. I snapped a couple photos of the end result. Once I receive my replacement wiring harness/relay and my passenger side MH1 becomes operational, I will post some better cutoff and light output shots.
Evan
Mods are as follows:
- oem projector STI-R clear lens swap. spaced +9mm
- Mini H1 (oem angel eye and corner light delete)
- HD Relay
- 55w DDM + Morimoto 5Five 5k
- 35w Morimoto DSP + DDM 5k
- Orion V2: Custom "Horse Shoe" design
- Frosted Fins
- Aluminum oem shroud
- Flat black everything else
- Cree XB-D Amber turn signal bulb
[IMG]https://lh4.googleusercontent.com/-s6Bhb8nTdPU/VCy_Q5vBC7I/AAAAAAAAGAo/pAh3vATMmwE/w1215-h911-no/IM
G_3115.JPG[/IMG]
Old 10-02-2014, 06:50 AM
RIHI's Avatar
My Ride: BMW
I like it, Evan. looks, really good.
Old 10-02-2014, 04:33 PM
Duperstar's Avatar
My Ride: 2009 535i xdrive --- JB4 G5 iso --- BMS intake --- e85 ---
Model Year: 2009
Very cool
Old 10-02-2014, 06:32 PM
Booyaazaa's Avatar
Looking good. I had Simon do my V4 install and light mod.
Old 10-02-2014, 07:18 PM
ucsbwsr's Avatar
Engine: N54
Thanks for the kind words.
Booyaazaa: Your lights look great. I was hesitant to go through with the blacked out look since it is abused on many cars but done correctly, works. I actually went through a couple phases with mine before settling on this appearance. One involved only running an outer angel eye and another have the whole headlight painted aluminum (like the oem shroud) but they didn't look right. I kind of wish I painted the oem shroud white but the aluminum does match my intercooler.
I am so pleased I went through with this mod: to having legit angel eyes, a custom look, and far superior light performance these headlights really satisfy in many ways.
Now the girlfriend's Prius goes under the knife!
Here is another photo,
Evan
Old 10-02-2014, 11:19 PM
530dE60's Avatar
Awesome
Old 10-03-2014, 01:51 PM
RIHI's Avatar
My Ride: BMW
Hi Evan,
Did you have to code the corner lights out? What is the material/parts cost for this mod?
Thanks.
Old 10-03-2014, 07:04 PM
ucsbwsr's Avatar
Engine: N54
I did not the only warning(s) received are for the angel eyes, I ditched the wiring harness and tapped them directly into the preexisting wiring presumably bypassing the resistor built into the harness, and since they are low voltage I will need to code them out. I also plan to run a trigger wire from the interior lights so the AEs fade on/off.
Evan
bestofthebest
03-28-2016 02:47 PM
JeremyR
02-06-2016 10:23 AM
umnitza
11-25-2015 11:10 AM
alexbaldy
09-28-2015 12:28 PM
Quick Reply: QUAD PROJECTOR RETROFIT ON MY E61: A few photos
