Plasti Dip BMW 5 Series
My Ride: 530i
Engine: M54
I lived in DC for twenty years (Springfield/Arlington). Don't worry about the salt damaging your car. It isn't NEARLY as bad near you as it is further up north with respect to salt on the roads. Wash your car regularly in the winter months just as you would in spring and summer, and give the underside of the car a good rinse when you do. When spring comes, remove all of the shielding from the underside of the car, give it a good hose down with fresh water, and you're done.
My Ride: 06' Range Rover Sport
I never did it, but I knew someone on my last forum who did it a few times to his G37. If its something temporary its okay but too much time in the sun leaves it baking onto the paint. Also removing it after some time to bake is not easy. You are looking at a day of scrubbing and hopefully your paint doesnt get wrecked. Im in Socal so hot and dry summers. Winter with little to no sun might be different but it still becomes a pain to pull it off all the little parts all over the car.
Looks good and no worries about the plasti dip "so called baking to the paint and not coming off". Everyone with real experience and when done right knows this stuff comes off with ease and you clearly have enough coats. Assuming you preped the car properly, you are golden. Enjoy.
Sorry for thread jacking infamuzzkilla
My Ride: 07 550i
All the people who complain about peeling issues use too little number of coats (can vs spray gun) and/or are buying the plasti dip in full strength and mixing in the paint thinners themselves (very common in Ca since it's illegal out here).
Assuming you use a gun with the correct sized tip, are using the plasti dip spray (not thinning yourself), lay down 6 coats minimum with the correct distance and temperature (spray too close and it will run, too far or too hot and it will dry as it hits creating texture), and prep the car properly, you can have amazing results with a very clean smooth finish.
Plasti dip gets a bad name from all the younger kids on the forums spraying their car in their garage with a 6 pack of cans found from their local hardware store
My Ride: 2008 535i
It also chips very easily from rocks, curb rash, scratches etc. Personally, I would never plasti-dip anything on my car. BMW's original paint jobs on their cars is an insane process - I wouldn't want to ruin that (a similar process would be $5000+ to have done).
My Ride: 04 525i, 04 Dinan M3
I may get flamed for saying this, but here goes nothing:
I think you ruined that car by plasti-dipping it. It looks decent in pictures other than the overspray noted by someone else, but I'm sure up close it looks like, well, plasti-dip. There is no substitute for a proper finish using quality paint and materials.
If I were hell-bent on changing the color of my car, I would have wrapped it. At least vinyl is removable and shouldn't damage the paint underneath. That plasti-dip is going to oxidize and etch its way into the paint. In short, it's never coming off and I doubt it'll still look good 3-5 years down the road.
That's just my $.02, if you're happy with the car then that's all that really matters.
I'm getting ready to do mine soon. I've wanted to do it for a while. There is a new range of stuff that takes it to another level. Its more of a professional option but the results are incredible. Still have to decide what color.
Just as a update, I plan to plastidip my ride in the next few months. I purchased the sprayer setup for it. Still deciding on colors but may be going with nardo grey.
Or maybe something more crazy like color shifting.
srogers535x
14
04-26-2015 09:39 AM
