Is my hood emblem bolted on or glued on?
My Ride: 2006 530i
this is a 2006 530i. my hood emblem has a big chip so I want to replace it. I see on ebay that alot say they are 2 pin but looking on the under side of the hood I see no way mine could have pins since there is no way to get to it. Are they just put on with sticky tape or glue or something?
My Ride: 530i
Engine: M54
neither. it is pressed into plastic grommets that are pressed into the hood. best way to remove the emblem is to put some masking tape on the paint, take a small plastic pry tool, and gently pry the emblem out. the pins that press into the grommet are at the 9 o'clock and 3 o'clock positions on the emblem. google it, there are tons of pages/videos that show you how to do it. on the newer F-body cars, BMW started putting double sided tape on the emblems (no idea why, the grommets method worked fine for five decades+). E60s use the same emblem and grommets that BMW used for decades on other cars.
not a bad to buy two grommets and have them on hand. I always put new ones in. theyre about sixty cents each, and can be pulled out carefully using needle-nosed pliers.
good luck.
good luck.
My Ride: 2006 530i
good luck.
good luck.
My Ride: 530i
Engine: M54
new one presses in by hand. get the pins lined up with the grommets, then give it a good slap and it'll go right in.
here's a video:
