Sponsored by:
Sponsored by:
Fault code 2820 2821 (n62)
Old 08-20-2016, 10:45 PM
cointilt's Avatar
Default Fault code 2820 2821 (n62)
Hi all, I pulled a couple fault codes from inpa which were 2821 and 2821 which is a bad manifold flap adjuster (disa),has anyone done this fix? I can't find much on the Internet and one chap mentioned about having to remove the manifold to get to the bottom screw from underneath. I can get to the top screws after moving a lot of the wiring and other bits.
The symptoms are a rough idle and sometimes get a misfire if driving enthusiastically. Any feedback would be great!
LandRange
06-06-2018 10:29 PM
mossieee06
02-12-2016 03:44 PM
5zeries
01-10-2016 12:42 PM
ranger530i
10-24-2015 12:59 PM
Quick Reply: Fault code 2820 2821 (n62)
