Dynamic Stability Control (DSC) Malfunction - 5Series.net - Forums
LinkBack Thread Tools Search this Thread
Old 04-21-2006, 09:19 AM   #1
Freewilly's Avatar
I had a warning message Dynamic Stability Control Malfunction pops up few days ago, and ask me to contact BMW dealer ASAP. I had an appointment made for this morning. The warning message pops up every time right after I start up for 3 days. But since last night, the warning message stopped, I called the dealer and canceled the appointment because I don't think they will do anything if there is no warning message.
Does anyone experiencing the problem before?
Freewilly is offline   Reply With Quote
Old 04-21-2006, 09:59 AM   #2
Freewilly:
I have gotten the message a couple of times. It usually happened when I was sloppy in a turn - in third gear instead of second. The message has always gone away when I restarted my car. I haven't seen it in a while - I must be paying better attention to which gear I'm in. It never required a dealer visit, just a restart. Hope this helps, good luck
juan2mini is offline   Reply With Quote
Old 04-21-2006, 10:24 AM   #3
freed0m's Avatar
Hi Freewilly,
Not sure if your warning message is the same as mine (see attached images). However, I recommend that you let the dealer take a look at your car anyway for possible prevention in the future. Since you are not in a hurry at the moment, make sure to schedule your appointment ahead of time so your can request for a BMW courtesy car.
Best regards,
Freedom
Dynamic Stability Control (DSC) Malfunction-dynamicdrive_01.jpg   Dynamic Stability Control (DSC) Malfunction-dynamicdrive_03.jpg   Dynamic Stability Control (DSC) Malfunction-dynamicdrive_02.jpg
freed0m is offline   Reply With Quote
Old 04-24-2006, 12:55 PM   #4
Freewilly's Avatar
Yes, it is exactly the same as mine. But the problem went away after 3 days, it's been working okay for now.
Old 04-24-2006, 01:10 PM   #5
jgbmw's Avatar
how does this technology work anyway? anyone have any info on this?
jgbmw is offline   Reply With Quote
Old 04-24-2006, 01:20 PM   #6
ImolaRedM's Avatar
Quote:
If it's like ACE in my (BMW Developed) Land Rover then it's a hydraulic sway bar with two gyro's (one high and one low) on the car to measure force. When needed there are hydraulic rams that applies force on the sway bars to counter the body lean. I would think the E60 has a more refined version of this but the principal is the same. If there is a failure the biggest problem would be that you have more body lean. But in the case of the Land Rover, you can also do real damage to some of the components unless you swap out the serpentine belt and bypass the hydaulic pump. It sounds like the E60's system is improved in that area.
ImolaRedM is offline   Reply With Quote
Old 04-25-2006, 10:25 PM   #7
Freewilly's Avatar
Damm, the error message comes back again. I am calling my dealer.
Old 04-25-2006, 11:27 PM   #8
freed0m's Avatar
Yes, the error won't be remediate until the dealer diagnose the problem . Even though the warning message does go away, there are error logs that the system will keep for trouble shooting purposes.
Old 04-26-2006, 01:44 AM   #9
needforspeed's Avatar
In my experience intermittent problems always hide themselves, when you book them in for repair. It's the 'law of sod' in action.
My car was in for a sticking drivers window, ac fault and battery drain error report this week.
Predictable the window fault and the error message hid themselves nicely and refused to play up.
BMW were fine though and took action anyway.
needforspeed is offline   Reply With Quote
Old 04-26-2006, 03:22 AM   #10
Shebs's Avatar
Is it the Dynamic Stability Control or the Dynamic Drive?
Shebs is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Authentic AC Schnitzer Type III Wheels 19" umichchris Private Member Classifieds 13 12-10-2015 02:00 PM
2007 BMW E60 NBT iDrive retrofit from 2014 F30 Germaniks E60 Parts, Accessories and Mods 11 08-09-2015 11:46 AM
FS: 2008 535i Sport/Premium 55K miles (SOCAL) sebash Complete Car Sales 3 07-30-2015 01:40 PM
Car turns off Padilla74 E60 Discussion 0 07-19-2015 04:08 PM
My brand new 535i MSport 525d MSport F10 Discussion 0 07-12-2015 08:03 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
All content Copyright 2012 by Internet Brands, Inc.
