DIY : Change LM1 to LM2
Old 09-29-2012, 06:40 AM
  #21
bojan.u's Avatar
Hello,
I sucesfuly change the lm2 and use this DIY(win in lm is correct)(and change rear and front lights+revire like in the official manual), but my car still has faults(blinkers, rear lights, rings in front dont turn on). I attach my trc, I dont know it is for LM2 ar LM1... or must I code (change) trc files too?????
File Type: txt
Old 03-27-2013, 09:28 AM
  #22
F-Tar's Avatar
My Ride: BMW Alpina B5 -05
Might be a stupid question but just making sure. I have a late 2003 e60 with lm1.. and a buddy of mine got a 2006-05 to be precise.. Do we have the same lma modules?
Old 03-27-2013, 12:54 PM
  #23
bruce_miranda's Avatar
yes
Old 05-09-2013, 02:16 AM
  #24
vinge87's Avatar
Originally Posted by nomis_nehc
If you got a new LM2, it's far more straight forward than this.
Is there a DIY giude?
I have a brand New LmII...
Old 05-09-2013, 10:50 AM
  #25
balbs's Avatar
My Ride: BMW
I have a pre-LCI with LCI tails and Bruce cables. I had a brand new LM 2 installed and had the AE welcome lights activated. (All thanks to Simon )
All is working fine. Is it possible to just disconnect the bruce cable adapters and plug straight into the LCI tails or does more coding have to be done?
Old 05-09-2013, 05:47 PM
  #26
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
More coding will be necessary.
Old 05-10-2013, 10:06 AM
  #27
balbs's Avatar
My Ride: BMW
Thanks. Man I should have remembered that when you were doing the LM2 coding for me.
Old 12-14-2016, 05:25 PM
  #28
richie281vn's Avatar
My Ride: 2006 525i
Model Year: 206
I retrofitted LM2 and did all the coding including Tool32 for the new VIN. Now in NCS expert the vin still shows for LMA but for INPA, the module still shows the old VIN and the ZUSB is not recognized. I tried Winkfp but they still cant recognize Zusb. I have latest v56 daten file and did all updates via dcan cable. The zusb now shows 9****** instead of the correct 9203082 showed in INPA
I also tried using Tool32 and c_fg_schreiben and c_fg_auftrag the LM_AHL_2.prg to write new vin without success. WinKFP still doesnt recognise the ZUSB.
The attached screen shows there are 2 different version of AIF in the module so possibly the previous owner didn't completed his job of write VIN and/or AIF. Any ideas on how should I proceed this? Thanks
Any suggestion to get this done/
My headlights now are flaking with left beam intermittently goes on and off and the control switch does not work in line with the headlight.
Old 01-15-2017, 12:26 AM
  #29
Lustek's Avatar
My Ride: E83 3.0d
Hi,
My friend asked me for help in coding a new LM2 module. The problem is that he has AHL lights and bought the module without this option. It does not care for AHL.
Only standard Xenon lights. Do I need to change some pins in the module, or simply cod and remove the code 524 with the FA?
rackhacker9275
05-11-2018 04:05 AM
UltimatePeter
DIY: Do It Yourself
09-28-2015 09:12 AM
Stranger12
Lounge
05-21-2015 12:47 PM
thesalboy
04-08-2015 09:13 AM
1WkdM5
03-09-2015 06:23 AM
Quick Reply: DIY : Change LM1 to LM2
