DIY : Change LM1 to LM2 - Page 2 - 5Series.net - Forums
Go Back   5Series.net - Forums > E60 5 Series (2004 - 2010) > E60 Discussion
LinkBack Thread Tools Search this Thread
Old 09-07-2011, 08:58 AM   #11
umichchris's Avatar
perhaps i should be more specific with my inquiry. what im curious about is whether this LM2 module will work with my pre-LCI Xenon headlights and later work with LCI Xenon headlights should i choose to perform the retrofit...
I dont see the letter AHL on the unit.....but i also cannot discern what LHR means either....
thanks for the help guys!
__________________
Bubbly Receptionist at
republicwerkz.com
#projectscarletletterM Build Thread
Matte Red Metallic ///M5
#operationV10 build thread
Matte Anthracite ///M5
umichchris is offline   Reply With Quote
Old 09-07-2011, 09:11 AM   #12
BlaSTiWi's Avatar
Perhaps you didn't understand my answer.
Let me try again, look up the p/n I pulled up for you and you'll see it's not S524A option capable (known as AHL or commonly Adaptive), so will it work for Xenon? Yes, but you'll loose Adaptive functionality.
That is why in my answer another easier way is to find out is from the donor car itself, if it's Xenon equiped then you are set 'cuz US bound model when equiped w/ Xenon will always AHL/Adaptive capable but if you can't find out you'll need to look it up based on the part number or query your local dealer.
And it's LWR (not LHR) it means vertical aim control or commonly known as self-leveling in scope of the headlight.
If you wonderin' how I know ... I'm using similar module (the 1st older version/generation) & I've done tricked/modded head/tail-lights conversion then I did the full conversion at the end in which I'm using LCI Bi-Xenon headlights but non-Adaptive Euro version.
GL!
__________________
Heavily modded xi/xDrive/AWD
BlaSTiWi is offline   Reply With Quote
Old 10-22-2011, 06:13 AM   #13
livefour2day's Avatar
Just trying to code my LM2 which has been pulled from another car but i have two problems hopefully someone can help, the first is my version of Win KFP is in German does anyone know how to wsitch it to English, i can find where to perform step 5
i have even tried to skip to step 6 and get the following error when i try to FA Write my LMA it keeps coming up with "COAPI-2000:EDIABAS or SGBD error SYS-0005: Object file not found.
please can someone help me my car is in bits and i cant go any further.
thanks
__________________
Retrofits completed so far -
Bluetooth module
Professional Sat Nav
LED door handle DIY
Footwell Lights
LCI Halogens with HID
AC Basic to AC High
livefour2day is offline   Reply With Quote
Old 10-22-2011, 06:29 AM   #14
BlaSTiWi's Avatar
When NCS popped up an error is pretty much generic error, it's better to find the log and post it up as it has much more detail.
More than likely you will need to update the DATEN files in order for EDIABAS to read/talk to the newer LM2.
thanks
__________________
Old 10-22-2011, 07:41 AM   #15
absolutly spot on BlaSTiW thank you updated my DATEN files etc (which Blood advised me to do weeks ago with my AC upgrade, but i didnt then)
all working now my VIN coded to the LMA2 Bruce is spot on with his DIY so thank you Bruce only issue i have is in my Check control on the idrive it says "Rear light right failure" i think its because i dont have LCI rear lights on my car yet.
Also big bonus is its stopped the headlight failure i had with my LCI fronts.
can anyone advise if its beacuse i dont have LCI rears or a coding error in my check control.
thanks
__________________
Bluetooth module
LED door handle DIY
Footwell Lights
AC Basic to AC High
Old 10-22-2011, 08:35 AM   #16
I am sure i have done something wrong the welcome lights only come on when i unlock the car with my key they will not come on when i unlock using my remote the go off with the remote...
i have removed my door card on the drivers side as i am changing it to LCI, which effects the unlock with the remote as i dont have the inside handle connected would it be that is what would be doing it.
__________________
Bluetooth module
LED door handle DIY
Footwell Lights
AC Basic to AC High
Old 02-07-2012, 11:01 AM   #17
sd_dracula's Avatar
Bruce, is the plug on the LM2 the exact same as LM1? As in there is no need to rewire anything right? Straight swap?
__________________
BMW 520d E60 2006 Factory M-Sport | Carbon Black| Factory tints | Rolling on Alpinas | Matt Black Grilles | Factory Boot Spoiler | ACS Roof Spoiler | Model Designation Deletion | LED Side Markers | Carbon Black Badges | Full LED Interior Kit | Licence Plate LEDs | De-flapped | LCI Headlights + 6000k HID | Projector Fogs + 6000k HID | 10W CREE LED Angel Eyes | Dension 500 + BTA1500 | Multimedia Interface + iPhone Video-out on iDrive Monitor
sd_dracula is offline   Reply With Quote
Old 02-07-2012, 02:16 PM   #18
Yes straight swap.
__________________
BMW E60 520d SE Saloon M47 2.0d, Titanium Grey II, Grey?Dakota Leather, Visibility Package, Media Package, Through Load System, Lumbar support ? fr seats, Automatic Air Conditioning?Advanced, High beam assistant, Hi?Fi Loudspeaker system, Heated Front Seats, Heated Steering Wheel, Extended Voice Input Retrofit, Auxillary Input Retrofit, DMS, 19" 172M Sport wheels and spare, HTC WM5 phone cradle DIY, Rear Power and Aux sockets DIY, Footwell lights DIY, Mic Mute DIY, Boot parcel net DIY, LCI Tail-lights DIY, Subwoofer and Aftermarket Amplifier DIY, BMW 0+ Car Seat Travel System DIY, Dension Gateway500 DIY, Dension IVE1000 iPOD Video DIY, ACM Retrofit DIY, Bootlid Reverse Camera DIY, Door LEDs DIY, Illuminated Shift Knob DIY, Mirror Puddle lights
Stuff for Sale.
LCI Tail-lights V6 retrofit cables,
Exterior Mirrors
HTC TyTn or TyTN II phone cradle
Boot parcel net
bruce_miranda is offline   Reply With Quote
Old 02-07-2012, 03:03 PM   #19
sd_dracula's Avatar
Perfect. Is that the case even if lets say the new LM has xenon/adaptive headlights option and the old one had halogens only?
Should do right, since halogens are the most basic headlight option and xenon one would include that also?
__________________
Old 08-18-2012, 09:25 AM   #20
Hello my Frend,
Firstly sory for my English, i M form switzerland
I have bought LM2 for my VFL 06.2006 E61,
I have gone like DIY instruction, but my winkfp will not work, i dont know why,
and my second problem is, i have only headlights to retrofit, backlights are VFL.
i m wery happy if you can help me.
Best Regards
anahtar is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
BMW e60 Brake Rotor Replacement 5 Series DIY UltimatePeter DIY: Do It Yourself 5 09-28-2015 09:12 AM
choosing a weekend car Stranger12 Lounge 3 05-21-2015 12:47 PM
HELP! Heavy white smoke out tailpipes Ė smells like gas (not coolant) thesalboy Other BMW Models 2 04-08-2015 09:13 AM
New 535xi owner looking for some Diy mods rackhacker9275 E60 Parts, Accessories and Mods 6 04-03-2015 07:23 PM
Bruce Miranda 6.1 Cables $400 1WkdM5 Private Member Classifieds 0 03-09-2015 06:23 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
All content Copyright © 2012 by Internet Brands, Inc.
