airbag light - restraints systems on E60 530D
My Ride: BMW 530D e60
Hello,
No. I tried to open the SZL and repaired it, but it's not possible because an electrical component important should be destroy.
Currently, the problem is still present.
It's impossible to repair the SZL, just replace it.
I bought a used but correct SZL (coming from a similar car) but I dont't know how to do ?
If a change only the VIN (NCSEXPERT), is it working ?
If I use Progman ou ITSA on a used SZL, is it working ?
Thank you
Thank you
I don't understand: Huh: ? Can you explain please?
Thanks
edit :
Maybe airbag matt sensor is : Bmw Passenger Occupancy ?
I tried but it was not working, SZL fail...
Can I recode another used SZL with progman ? Is it working ?
Thanks
Thanks
edit :
Thanks
Passenger seat has an occupancy detector seat mat. Sometimes it goes bad. Shows the airbag message on the iDrive. There is a recall in the US for many models. You can also put in a bypass for the mat that involves an electrical piece that plugs into the wiring harness basically telling the car that someone is always in (never in?) the passenger seat and doesn't rely on the mat detector.
Szl fail...
SFx550i
04-14-2015 05:00 PM
