550i M-sport - wandering and getting loose
Old 05-28-2015, 08:56 AM
BrandonSS's Avatar
My Ride: Alpine White 550i M Sport
The car has dynamic handling but no active steering. Dynamic handling was gone through and tested (was cool to watch when they did the computer test). It didnt feel like excessive body roll, but, I'm not sure. It definitely cut power as traction control does, that is what made me look down at the cluster to see the traction light flickering.
Old 05-28-2015, 10:13 AM
star69me's Avatar
My Ride: BMW 550I BLK
Engine: N62
Where can I find a steering rack that won't brake the bank... I have some same symptoms but i know my rack is bad.
07 550i
Old 05-28-2015, 10:57 AM
dingolfing's Avatar
My Ride: 2008 550i
What about checking the 4 rear subframe rubber bushings for wear?
Old 05-28-2015, 11:09 AM
BrandonSS's Avatar
They said they dropped those to inspect for metal fatigue. He said it was a long shot but apparently some of the E46's had it happen so it was worth looking. They found nothing, so I'm assuming they also checked those while back there.
Old 05-28-2015, 07:13 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
put your boots on and go around and kick the tires hard. see if any bounce odd. or maybe even jack up each corner and grab and try to wiggle each wheel. it sounds like something is loose.
Old 05-29-2015, 07:08 PM
cakes's Avatar
My Ride: 550i
Model Year: 2010
what tires do you have? what rpm/gear are you in when it's loosing grip through the corners?
Old 05-29-2015, 07:53 PM
turboawd's Avatar
i wonder if you have a tire with a slipped belt possibly. spin the wheels while jacked up and see if there is any obvious wandering.
Old 10-24-2019, 09:01 AM
BMW E61 535d's Avatar
My Ride: 2005 BMW 535d Individual
Model Year: 2005 BMW 535d Individual
Engine: 535d
Hi, did you ever find out what the problem was? I have the same problem and dynamic drive. Feels like the rear is steering. I suspect worn crossmember bushings.
TopPMP
05-02-2023 04:20 PM
BrandonSS
04-19-2016 05:11 AM
BrandonSS
09-03-2015 07:09 PM
Margal
07-31-2015 01:18 PM
e60fans
07-27-2015 04:52 AM
Quick Reply: 550i M-sport - wandering and getting loose
