Sponsored by:
Sponsored by:
545i manual - momentary power loss
Old 10-27-2014, 06:49 AM
Weebz's Avatar
Will do. Going to be a little bit. Car is in the body shop from a momentary lapse of paying attention on my end!!!
Old 11-04-2014, 07:08 PM
mlawkevin's Avatar
My Ride: 2015 M5 competition package, black-on-black
Originally Posted by Margal
I had the same problem a few weeks ago. mine started same way momentary power loss when accelerating from lower gears. there was no codes at the beginning but then I got misfire and SES light. replaced all ignition coils and no problem since. everything is normal. one of your ignition coil is going bad. you can replace all of them or wait till codes come on to find out which coil is dad and replace that particular one or get the meter and check them individually.
check my thread also that I have started a few weeks ago
https://5series.net/forums/e60-discu...-speed-139725/
Thanks for the advice, though don't think this is my problem. I put in new plugs and coils about 10k miles ago. I noticed this weekend the clutch slipping when I stand hard on it in higher gears (4th and 5th) so looks like I'm headed in for a new clutch. I'll report back if that solves my problem in first gear, though I'm still dubious as it really does only do it once and then goes away. I'll keep troubleshooting after the new clutch (and while I'm at it, short shift kit, CDV replace and rpi exhaust) go in. Thanks.
Old 01-26-2015, 09:17 AM
Ben535xi's Avatar
Originally Posted by mlawkevin
I've been scouring the net for weeks and can't figure this out. I have a 545i manual and pretty much every time I drive it, without fail, after about 1-2 minutes, as I'm accelerating, the car will momentarily lose power (like half a second). it only does it once and only within the first couple minutes of driving. I can't for the life of me figure it out. Anyone else experienced this or have any ideas?
hello all!
I have a similar issue. It is happening sometimes at highway speed while going uphill, under half a second. My car is a 2008 535xi.
Any idea of what the problem could be?
Thanks!
Old 01-26-2015, 05:32 PM
BrianTx5's Avatar
My Ride: 2005 545i | Black Sapphire Metallic | Black Dakota Leather | Anthracite Maple | 6 Speed Manual | Sport Package | Logic 7 | Sirius Satellite Radio
Model Year: 2005
I noticed this weekend the clutch slipping when I stand hard on it in higher gears (4th and 5th) so looks like I'm headed in for a new clutch. Thanks.
How many miles on your clutch?
YannickVT
05-07-2015 11:45 PM
Stranger12
04-12-2015 02:07 PM
08-12-2003 11:41 AM
06-17-2003 09:38 PM
Quick Reply: 545i manual - momentary power loss
