545i Coolant expansion tank replacement - HELP! - 5Series.net - Forums
LinkBack Thread Tools Search this Thread
Old 09-18-2011, 04:03 PM   #1
Cruiser565's Avatar
Hey everyone,
So it turns out my coolant expansion reservoir has a pinhole leak in it and blew out a good amount of coolant on my way home from church this morning. I have done a pretty thorough search of this forum and have found a great DIY for the replacement procedure, but I have one important question... after I get the new tank in place, do I need a complete coolant flush/bleed or do I just follow the venting/filling procedure as follows:
(50% BMW antifreeze and 50% distilled water, 15 US qt) and venting system at the same time.
-Switch ignition ON without starting engine.
-Set blower fan to low and temperature for driver and passenger side to full warm. Set seat heat to MAX if available.
-Fill expansion tank slowly until Max level.
-Leave cap open and run engine at idle for 1 minute.
-Adjust level to MAX and close cap.
-Run engine to operating temperature.
-Shutdown engine and after engine has cooled, recheck coolant level.
Also, and this maybe dumb, but can someone tell me how to loosen the BMW hose clamps... they don't appear to be like any other hose clamp I have ever worked on before.
Thanks for all the help!!!!
Will
Cruiser565 is offline   Reply With Quote
Old 09-18-2011, 09:33 PM   #2
turboawd's Avatar
no need to flush.
just do as stated above, but i dont know why you have to turn on the seat heaters??
turboawd is offline   Reply With Quote
Old 09-19-2011, 05:25 AM   #3
Cruiser565's Avatar
Yeah... I saw that one too. The only thing I could think of was some of the 7's have the ventilated heated and cooled seats, so maybe the instructions were universal. Thanks!
Old 09-21-2011, 09:50 AM   #4
i did this on my car afew weeks ago. it took about 20 minutes. Hose clamps are attached by a little pin on each clamp. you need to pull them out with needle nose pliers carefully so they dont fall down the engine. once you remove them , the hoses will come off the reservoir tank. very easy. i did not follow this procedure you have, just tapped off the coolant level. maybe i need to recheck the level now. good luck
zinchuk77 is offline   Reply With Quote
Old 09-21-2011, 09:52 AM   #5
Old 09-22-2011, 05:11 AM   #6
Cruiser565's Avatar
Quote:
Thanks!... yeah, I knocked this out on Monday in about 30 minutes total time, waayyy easier than I expected it to be, but fairly messy. I thought those pins went all the way around and was amazed when the first one came off in about 5 seconds. Anyway, thanks again for the assistance and to anyone else, DON'T pay the $350 the dealer/indy wants, DIY for $100 is the way to go!
Will
Thread Thread Starter Forum Replies Last Post
2006 BMW 525ix Kasmo E60 Discussion 17 10-01-2015 10:35 PM
Chadillac2000's 2008 BMW 535i Build Thread chadillac2000 E60 Parts, Accessories and Mods 41 06-03-2015 09:43 AM
FS: E39 2000 528i auto, 52,000 miles, NY RobR Complete Car Sales 2 06-02-2015 09:31 AM
BMW rubber and plastic......poor choice, or designed to fail? turboawd E60 Discussion 19 04-23-2015 06:17 AM
Engine drain plug/bleeder screw TheBlack5 E60 Discussion 2 03-11-2015 08:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
All content Copyright 2012 by Internet Brands, Inc.
