535i - 2008 " Engine Mailfunction"
My Ride: 535i
Engine: 3.0L 6cyl Turbo 6M
Hi;
I got the message Engine malfunction reduce power while I'm driving. I was very close to my work and I reduced the speed to 45 and park the car. Any ideas and suggestions what should cause the issue? I'm taking to the Mechanic tomorrow; but your inputs are appreciated.
Thanks
Thanks
My Ride: 535
first of all the only way to do this is to pull fault codes.
but i can throw out some idea as to what it can be.
most common issues are spark plugs and coils. easy job. part of maintenance
then you get into more serious things like, injectors or walnut blasting intake ports
(walnut blasting should be maintenance for these direct injection cars)
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Dont forget vacuum leaks!!
My Ride: 535i
Hi;
Thanks to all; I went to the BMW dealer and they was able to find the issue. vacuum leak - they fixed.
BTW, spark plugs and cols has been replaced around 6K - now my car is 71K. One thing they said this model is known for this can of faults when you trying to go for maximum throttle - I mean when you push the car above 6 or 7 rpm.
Again thank you all.
smidley
12-23-2015 02:14 AM
