Sponsored by:
Sponsored by:
BMW recommends castrol?
Old 08-26-2007, 10:18 AM
eagle12's Avatar
My Ride: 2008 BMW 535I Monaco Blue Cream Beige
Hi guys,
Thanks for the warm welcome to the forum. This is a nice place to get lots of info about our cars. Anyways I was wondering if there is any good reason why BMW says you should use castrol oils if possible. I'm stationed in Germany and cannot get fully synthetic castrol 5w 30 motor oil here. I can get Moble 1 fully synthetic 5w 30 so I will probably use that. Do you think BMW and Castrol have a deal together or is the oil actually the best to use in a bimmer for some reason. Thanks.
Old 08-26-2007, 10:50 AM
EBMCS03's Avatar
Probably a little of both. BMW probably has a deal with Castrol where Castrol provides BMW with free oil for development or something... so they'll ask people to use that in their engines in exchange... BMW probably designed and tested their cars with Castrol oil in the engine and so they'll continue to recommend the owners to use it. BMW also designs their cars under the use of Chevron Gas.. I read this back when it was the E39 not sure if it still holds true, probably still holds true, but does everyone use Chevron gas? Nope... I solely use 76 gas myself unless I cant find a 76 gas station.
You should be fine using Mobile 1. Thats good stuff. BUT dont mix them... make sure you drain the old oil out completely and try to flush it a little before adding Mobile 1
Old 08-27-2007, 06:02 AM
olli_535d's Avatar
My Ride: 535d Sport, carbon black, media pack, visibility pack, grey leather, heated seats, sun protection glass, voice control, Eibach ProKit, 19" 166 style wheels, e-maps ECU remap to 325hp and 640NM, top speed limiter removed
You're fine with any approved oil of the relevant BMW list (probably Longlife 04 list in your case)
BMW and Castrol have indeed a nice money spinning relationship. (apart from the fact that Castrol makes very good oils)
Here's the (january dated) Longlife 04 list. I also use the Mobil 1 ESP 5w-30 at the moment. Since January there were probably a few more oils added.
File Type: pdf
TroyE60
05-30-2019 05:01 PM
BLACK_PRINCE54915
04-02-2015 08:11 PM
mortyk
03-31-2015 04:49 PM
JonathonK
03-27-2015 08:13 AM
reckamech
09-08-2003 01:24 PM
Quick Reply: BMW recommends castrol?
