6HP19 Suprise today
6HP19 Suprise today
Normally any post regarding our ZF transmission is a bad post. This time I am posting that there was actually a pleasant surprise when I had my ZF serviced today. A little background on the car, 100k miles with the original fluid and pan, always driven hard and it's been FBO the last 40k miles. When my buddy Wing at Performance Technic drained and dropped the trans pan both the fluid and pan looked great. The fluid wasn't burnt, no chucks or debris floating in it. The pan was clean with zero build up. Also when he dropped the valve body both the mech sleeve and bridge seals were in great condition, no cracks and very pliable bridge seal. Pretty much all the techs said they were impressed with the condition of the trans parts how little wear it showed. During the test drive the trans shifted great, which it did before, but now the car breaks loose when shifting into 4th. So maybe the key to keeping the trans healthy is to drive it hard all the time, engine redline is your friend possibly.
My Ride: 2008 550i
That's awesome! I think 535's have the same transmission as the 550i, the 6HP26. 6HP19 is only rated for 295 ft-lbs, and we all know the 535i stock is underrated at 300.
The bridge seal may have been visually in perfect condition, but it might have shrunk in size, so I would have changed it anyway.
BTW, did you or the tech check to see what color the sleeve's rubber seal was? Was it the older orange or the newer black version?
My Ride: 2008 550i
Wait, is that the original mechatronics sleeve that you removed in the pic you posted?
If so, it looks like BMW (i.e. ZF) changed over to the newer sleeve sometime in 2008-2009, because my early 2008 6HP26 came with the older orange version which ended up leaking.
umnitza
11-25-2015 11:10 AM
