2001 e39 530i idle issues - 5Series.net - Forums
LinkBack Thread Tools Search this Thread
Old 08-17-2016, 08:13 AM   #1
Default 2001 e39 530i idle issues
I recently changed all the Ignition coils, spark plugs and oxygen sensors in my 2001 530i. Now the car doesn't idle correctly. I've confirmed that I installed the correct parts. It wasn't running bad before I changed the parts out, Engine has 190k, never had an issue before. I changed out the parts simply because of the high mileage.
Any insight or help would be appreciated!
dredheadz is offline   Reply With Quote
Old 08-30-2016, 02:47 AM   #2
Did you swap the o2 with genuine BMW sensors or Bosch ones? Or were they aftermarket? I've heard negative things about the the cheaper variants of sensors.
E34m525i is offline   Reply With Quote
Old 09-10-2016, 02:19 PM   #3
I removed the aftermarket ones and replaced them with Bosch. So far so go, the normal idle has returned and its drivable again. Thanks for the heads up, it was much appreciated!
Thread Thread Starter Forum Replies Last Post
2001 530i - Oil Filter Housing Gasket Hoosiers54 E39 Discussion 1 09-16-2016 02:35 PM
Spark plugs after 30K kskane E60 Discussion 9 10-21-2015 04:00 AM
coil-over installment question keno75 E60 Discussion 5 09-24-2015 07:47 PM
Car/Key Memory GotBMW E60 Discussion 34 09-05-2004 01:14 PM
car shipping!!!!! brian1225 E60 Discussion 17 03-10-2004 06:37 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
All content Copyright 2012 by Internet Brands, Inc.
