E34/E28/E12 Discussion Discuss the E34 (1989 - 1996), E28 (1982 - 1988) and the E12 (1972 - 1981) 5 series models here.
SRS LIGHT!
Old 03-03-2010, 05:24 PM
rubbster's Avatar
My SRS light just came on right after I hit a pot hole. It flashes untill I drive the car dor about ten minutes and the stays on after that. My friends shop tried to read the codes and it came up SRA Fuse,Relay. Now the fuel relay is in the control module. I want to see if anyone else has input on this before a spend the money on that. My friend will not rip me off. I get parts for cost so im not worried about someone taking advantage of me to make money. ANY THOUGHTS?
Old 07-08-2010, 07:58 AM
spazman1990's Avatar
Yeah my other bmw 1990 525i had that problem when i unhooked the steering wheel and then it came on. now i have the battery light on the Gage cluster and then i swapted the engines from one bmw to my 1989 525i and i dont have the srs light on you can always take the bulb out.. thats what i tryed to do.
Old 07-08-2010, 08:26 AM
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
Find a good independent Airbag Service/Repair shop in your area. I had the same problem last month when I opened my driver side door trim and left the side airbag module unplugged. It cost around $50-80.That fault may or may not have deactivated your airbags, so get it fix ASAP for your safety.
B20forlife
07-20-2020 07:31 PM
DJ JoeyG
11-09-2015 07:24 AM
aarong15
E39 Discussion
07-09-2015 07:01 AM
i545i
06-14-2015 06:36 PM
bruce_miranda
DIY: Do It Yourself
12-12-2012 05:06 PM
Quick Reply: SRS LIGHT!
