Remove rear bumper E61
My Ride: 2008 520d Touring with insufficient toys.
Hi, Appreciate this is quite an old post, but can you remember what other fixings other than the two bolts in the tailgate area have to be taken off to remove the rear bumper. Also, any tips for picking up the wiring for the electrics? I'm obviously going to use a bypass relay but was wondering where is best to pick-up and if you still have a note of the vehicle colours.
Cheers, Mark
Cheers, Mark
My Ride: Bmw 530d 2004
Cheers, Mark
Cheers, Mark
- Antti -
Do you have a link for the electrical systems too? Was hoping to find the wiring for the tow electrics. Is there a good pick-up point or just tap into the wiring at the light cluster?
Also as I usually make a mess of getting the expanding rivets out any idea of a good source of replacement ones?
Thanks.
Mark
Thanks for that. Looks reasonably straight forward. Guess I need to get hold of the TIS disks for the new one as my previous set only went to 2001 so doesn't cover mine at all.
Thanks.
Mark
Thanks.
Mark
Here's the wiring diagram: http://spaghetticoder.org/bmw/wds/e60e61/
And here's the online version of the TIS: http://tis.spaghetticoder.org/e60/
- Antti -
My Ride: '06 530xiT
Just thought I'd note for any inquiring minds that AlwynMike's instructions are spot on; bumper is really easy to remove even for a total noob like myself. I was able to put the rivets back in without issue, we'll see how they hold up.
My Ride: 535d touring
cant get my rear bumper off
Thanks Mike
Actually, the job was even simpler than that! I just needed to remove 2 bolts (1 each side). I've attached a picture (in a Word document) to show where they are located.
Cheers, Paul.
Attachment 102375
Cheers, Paul.
Attachment 102375
hi I seem to have the same rear bumper as yourself but I still cant get it off undone the 2 bolts from your pic and the 4 in each wheel arch, am I missing something or am I just being a whimp trying not to damage the bumper
Administrator
Unfortunately, carsonbleu hasn't been on the forum in almost 5 years. That's the problem with responding to old threads. People come and go. Hopefully, someone else in this thread will see your question and respond.
socale39
09-05-2023 08:30 AM
