NCSExpert Code Mods
#721
My Ride: BMW
Does anyone know the specific coding and module that might affect the tilt steering wheel? I did a few things a while back and thought I simply didn't connect something, or a fuse blew. Last weekend I went back under the dash and didn't see a thing. I also tested every single fuse in the car including the glove box and no dice.
I have an LCI and I did a sport mode mod, but I did not have to go into the dashboard where people said there is a plug by the heated seat/radio console, so I am ruling out having a plug there.
The last thing that I did was code out the steering wheel tightness when on sport mode:
GESCHWIN_WERTE_SPORT_KGM
STROMWERTE_SPORT_KGM
I haven't had a chance to take a closer look to see if my tilt steering motor is jammed or not getting power yet.. it has to get a bit warmer for me to do that again.
I have a pre-lci so I don't know if this applies. Anyway, when I did the sport mod mode in my car, my tilt steering stopped working. It turned out that I inadvertently slightly disconnected the harness that connects to the DCT button module just in front of the gear shift.
#722
My Ride: 2008 535xi
Engine: n54
It's possible it fell out of its own will... But I didn't go near that switch.. For the lci you need to access the glove box modules...
#725
My Ride: bmw e60 535d
help with pathway lights
Need some help getting this feature coded because it is not working on my car and i can't deal with it.I have bmw e60 535d 2004 lm1 i try to change
LMA: HEIMLEUCHTEN_FUNKSCHL >> aktiv
LMA: HEIMLEUCHTEN_KL58G_1 >> aktiv
but no succses.can anyone get me some help?I'm uploading a link with my original file
http://dox.bg/files/dw?a=f675c979a1
#726
My Ride: BMW 535i M-Sport
Model Year: 2010
alright guys I've run into my first problem here with coding.
I've coded a few features with no issues (folding mirrors/roll up windows via key fob, pathway lighting via key fob etc)
today I was trying to code my car to fold the mirrors via key fob with no delay, which I did successfully, but now my car does not chirp when I press the arm button via key fob. Unlock chirp works perfectly fine as designed.
Any ideas ?
Thanks
Any ideas ?
Thanks
#728
My Ride: 530ix
Model Year: 2020
help with coding
Everyone,
I updated to CIC and now I have lost my ability to use the parking ventilation, anyone know the setting that controls that?
I also lost my ability to use my trip meter completely, the rest button the instrument cluster does nothing, even after coding with a blank man file.
thanks
thanks
#729
My Ride: 535XI
Engine: N54
Any ideas ?
Thanks
Any ideas ?
Thanks
If not i can help recode.
