NCSExpert Code Mods
Old 08-08-2014, 07:17 AM
  #711
StoneFist's Avatar
My Ride: E60 520I SE
Originally Posted by tom_il
Nothing wrong. It doesn't work. You got a diesel ?
nope - 2.2 petrol
You need to replace the oil sensor too from a newer model, idk the part number.. This is a feature enabled by default on newer e60s
Was talking to my local steelers and according to them there's no new sensor as this one is being installed in newest cars as well. Anyway will have to change oil sensor as this one is giving me "oil level low" and "oil pressure low" errors many times and I'm checking oil frequently and it's always ok. Will do this when changing oil it two weeks time
Old 09-02-2014, 12:53 AM
  #712
530dA's Avatar
hai guys,
can any body help me with coding setting.
i have build lci navi prof with 8 radio butons in my car, the favorit button are not working.
0031626517430 i have whatsapp a help will be great.
and i have build mulf2 hih svs with usb aux, my bluetooth function is nit more working, car is from 2004.
i read that i need ssd file to read it in ncs and coded with icom B i have icom,
could anyone please help me iam confused ;-(
Old 01-21-2015, 12:07 PM
  #713
ianbmwe60's Avatar
My Ride: bmw e60 msport
Model Year: E60
Engine: 2.5
Default code for lock and unlock chrip
whats the code I select on ncs expert for lock and unlock
Old 01-27-2015, 04:14 AM
  #714
cmyachtie's Avatar
My Ride: 2004 545i+BT+AUX+Coding
Engine: N62
Cross posting(multiples) does not seem to work for you as I posted a link for you in one of your other 3 posts on same question.....learn to read maybe?
Don't expect any more answers from this guy.
Old 01-27-2015, 08:33 AM
  #715
ianbmwe60's Avatar
Model Year: E60
Engine: 2.5
can some 1 try and help me with a guide or instructions for ncs expert to get the accustic sound when looking my door and unlooking it plese help
Old 08-20-2015, 12:18 AM
  #716
Pepe Le Pew's Avatar
My Ride: bmw e60 535d
Default E60 10.2004 535d
I have hard times on finding how to make welcome lights working on my BMW because it is using LM1 and i can't find KGM module or CAPPL module or HUD to recode.Can someone help me with this one how to make welcome lights and where to recode?
Old 08-20-2015, 01:58 AM
  #717
fanarik's Avatar
Hello, for Welcome Light you need the LM2!
No need to code other ECUs
Old 08-20-2015, 02:51 AM
  #718
What about faster blinkers?Do LM1 haves them and how to do it because i don't get it right
Old 08-21-2015, 06:20 PM
  #719
dv8ed's Avatar
I have LM1 but only use Pathway Lighting.
LMA: HEIMLEUCHTEN_FUNKSCHL >> aktiv
For Welcome on LM1 try this without quotes:
"https://youtu.be/q5CAUqHIPWs"
Old 02-25-2016, 07:37 AM
  #720
rice_rocket88's Avatar
My Ride: 2008 535xi
Engine: n54
Does anyone know the specific coding and module that might affect the tilt steering wheel? I did a few things a while back and thought I simply didn't connect something, or a fuse blew. Last weekend I went back under the dash and didn't see a thing. I also tested every single fuse in the car including the glove box and no dice.
I have an LCI and I did a sport mode mod, but I did not have to go into the dashboard where people said there is a plug by the heated seat/radio console, so I am ruling out having a plug there.
The last thing that I did was code out the steering wheel tightness when on sport mode:
GESCHWIN_WERTE_SPORT_KGM
STROMWERTE_SPORT_KGM
I haven't had a chance to take a closer look to see if my tilt steering motor is jammed or not getting power yet.. it has to get a bit warmer for me to do that again.
Quick Reply: NCSExpert Code Mods
