KyleB's 6HP19 service thread
Old 09-01-2014, 09:29 AM
  #21
e60eric's Avatar
My Ride: 2006 530i Sport - Stock
Thank you, KyleB, for a great write-up.I started experiencing some rough shifts on my 2006 530i with 127k miles.I bought the car with 78k and never changed the fluid myself, and I doubted the previous owner did either.While doing my research I came across your great write-up and figured I would follow your procedure for the pan replacement and fluid refill only (steps 1-8 and 29-38), since my shift problems were intermittent and I didn’t have any codes.
A couple of tips they may help some folks.
Tip 1: Get a good fluid pump!When I did my 3-series a couple of months prior I bought a suction gun and it worked great for the thicker ATF for the GM transmission.It would pump 1 liter in 2 cycles.For whatever reason, the suction gun did not work for the ZF fluid.The ZF fluid is a lot more like water and I guess the seals were not good enough or the ATF from the first job destroyed them.In any case, I ran mid-job to Autozone and bought a cheap plastic pump that screwed to the top of the bottle and drove home praying that it would work.It did the job, but took 100+ cycles to pump 1 liter.I am not exaggerating!It got the job done and my fingers are stronger today because of it.
Tip 2: You can put 1 liter, maybe more, into the pan before you carefully lift it into place.I am glad I did this, given my bad pump experience.It saved some time.
I drained about 7.5 liters and replaced about 7.5 liters.No leaks and no intermittent shifting problems after about 200 miles.Keeping my fingers crossed!
Old 09-08-2014, 07:09 PM
  #22
p3style's Avatar
My Ride: 2004 545
Anybody in Socal willing to do this for me for some extra cash?
I can buy the parts - just looking to hooking up a fellow member on the install rather than paying an Indy Shop =)
Indy quoted me $400.
Pm me with offers please - I really need to get this done.
Thanks!
Old 10-08-2014, 05:18 PM
  #23
gcalo's Avatar
My Ride: 530i
Engine: N52
e60Eric
How did you get that much fluid in your unit? That is a lot of fluid.
Did you drain the system also at the cooler under the radiator?
Old 10-13-2014, 06:33 PM
  #24
e60eric's Avatar
@gcalo: I can't say I did anything special other than to let it sit and drain overnight. It seems like most people get at least 6L out just by opening the drain plug. After that I would say there is still almost 1L left in the pan/filter. Maybe I got another 0.5L just by letting it drip.
Old 10-13-2014, 06:46 PM
  #25
gcalo's Avatar
My Ride: 530i
Engine: N52
I know for a fact the pan holds almost 1.5 Liters. I have filled my old pan w/water and then measured it after filling.
Then there are 4 liters +/- the system will take.
I think by letting it drain overnight you may have achieved what I have estimated will be the return volume after I drain from the cooler as well.
Could be that you achieved that amount by the overnight drain.
I am doing mine this W/E for a 3rd time. I now have about 1K miles on 2nd fill.
So I will see what I yield by draining at the cooler as well.
My guess was 7 +/- liters.
Old 10-30-2014, 12:29 PM
  #26
txag_530i's Avatar
I'm about to embark on the fluid change and Mechtronics seal. Here's a video of the valve body assembly that I found to be of interest. The video shows some good details of removing the valve body.
Old 10-30-2014, 04:16 PM
  #27
gcalo's Avatar
My Ride: 530i
Engine: N52
If it's not leaking I'd leave it alone.
Don't invite trouble.
Old 11-08-2014, 07:09 PM
  #28
txag_530i's Avatar
It wasn't leaking and I didn't mess with it.
Thanks again to KyleB for posting this DIY.
I used an OTC (2359) Oil Suction Gun to fill the fluid. It was ~$18 from Amazon and worked a lot better than the cheap plastic types.
I decided to use Motocraft Mercon SP transmission fluid.
Old 11-08-2014, 10:04 PM
  #29
gcalo's Avatar
My Ride: 530i
Engine: N52
You used the right fluid for sure!
I can attest to that
Old 11-09-2014, 07:44 AM
  #30
KyleB's Avatar
My Ride: 530i
Engine: M54
Ford's 6R80 transmission is nothing more than a rebadged ZF 6HP26, so theoretically the Ford fluid should work just fine. You're not the first person to use that fluid in a ZF gearbox.
Best of luck to you and the car.
Quick Reply: KyleB's 6HP19 service thread
