Install paddle shift steering wheel??? Help please.
Old 05-06-2009, 03:03 PM
itiswhatitis's Avatar
My Ride: 2006 550i - Dinan Stage 1, Sprintbooster, Sport wheel retrofit w Paddle shift kit, Nav, Sat Radio, Logic 7, Sport Package, Cold Weather Package, Premium, Bluetooth, Rear Sun Shades, PDC...and some other stuff...
Thumbs up
Hi,
I have read the posts on how to install the sport sterring wheel, but they do not seem to explain how to install and wire a wheel with paddle shifters. I have searched "paddle shift install" and cannot seem to find the details I need. I have also read through http://forums.e60.net/index.php?showtopic=70023
Can you help me?
I have a 2006 550i with the standard wheel - no paddles. I have purchased a sport wheel with paddle shifters, and the round airbag (post 09/2005 as build date is 11/2005). How do I install this sucker so that the paddles work?
Thanks in advance for your help.
Old 05-06-2009, 03:18 PM
skeeter's Avatar
My Ride: '10 Switzer "Ultimate Street Edition" GT-R
You need to buy a kit...There roughly $300... You can get one from Fred member 530iM or member schulrog....
Old 05-06-2009, 04:59 PM
schulrog's Avatar
You can find it here: http://www.aftermarketbulbsshop.com/BMW-Pa...-p/bmw-pa-r.htm
Just let me know if you have the push/pull paddles or the illuminated +/- paddles.
Old 06-15-2009, 02:51 PM
Salvatore's Avatar
Hi Mate, I have an E60 LCI 530d M Sport. I don't have SAT but plan on retrofitting SAT. Can I fit this paddleshift kit to my car??
Thanks
Old 06-16-2009, 08:48 PM
schulrog's Avatar
currently I don't think anyone offers a paddleshift kit for the new shift knob style due to the difference or lack of wiring possibilities.
Old 06-17-2009, 02:31 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Originally Posted by itiswhatitis' post='870324' date='May 6 2009, 07:03 PM
Hi,
Can you help me?
Here are some other threads about this. Depending on your skill level, you can either buy a wiring kit or attempt to engineer one yourself...
http://forums.e60.net/index.php?showtopic=46814
http://forums.e60.net/index.php?showtopic=66942
http://forums.e60.net/index.php?showtopic=59918
http://forums.e60.net/index.php?showtopic=70176
http://forums.e60.net/index.php?showtopic=7689
Old 05-18-2014, 05:12 PM
scoopo16@hotmail.com's Avatar
My Ride: E50 530D MS
Default Have you had any success wiring your paddles to the gear shifter
Hi,
I have read the posts on how to install the sport sterring wheel, but they do not seem to explain how to install and wire a wheel with paddle shifters. I have searched "paddle shift install" and cannot seem to find the details I need. I have also read through Changing the original steering wheel to MSport one! - 5Series.net - Forums
Can you help me?
Hey Mate, I recently bought a 530D M-sport - the previous owner fitted the M5 steering wheel with the paddle shifters, he told me that they dont function and just need coding.
After some research I found out there is in fact no recoding required, I've found plenty of information that tells me I need to wire the paddles to the gear shifter however nobody has done a guide (or at least if they have I cant find one).
As I've said about the steering is fitted and the paddles are illuminated just not functional, any help would be greatly appreciated.
Cheers,
Fergus
Old 05-18-2014, 09:29 PM
stel_i79's Avatar
My Ride: 530i N52
Engine: n52
MotiveMods. ..Roger is your man!! Good luck
Old 05-20-2014, 07:38 AM
Myga's Avatar
My Ride: 535d 272km
Hey guys,
I'm trying to fit in the M5 steering wheel (the LCI version) in to my pre-LCI 535d.
I've already did one attempt when I observed what follows:
- My factory installed (M-sports) steering wheel is equipped with airbag module/connector inside the bottom arm
- My M5 steering wheel (LCI) does not have that module
- I've bought the LCI slip ring (equipped with airbag connector) but it wont fit the pre-LCI base
From there I've decided to buy the LCI base that will go with the LCI slip ring.
I checked the pictures online and they have the same connectors - just placed in different positions.
Now, I got the LCI slipring mounting base, that in theory should fit.
Before I take apart the steering column again I want to make sure if there are any surprises I should expect? My ignition slot uses a classic key with is obviously different than the LCI version. Should I expect any trouble trying to replace the whole set?
Old 06-13-2014, 03:39 AM
schulrog's Avatar
I would highly suggest getting a manufactured kit. from what i can read you are spending lots of $ on parts that don't fit.
Quick Reply: Install paddle shift steering wheel??? Help please.
