How to torque correctly - brake bleed screw and fumoto valve adapter
My Ride: 2004 525i, Metalic Gray, Premium Package
I need to make sure that I torque the following two correctly to the spec. I have the regular click stop torque wrench and bunch of sockets.
1. Brake bleed screws: the sockets are not deep enough to grab the hex surface at the base of the bleed screws. Not sure if deep sockets may solve the problem?
2. Fumoto oil drain valve: none of my sockets can grab this valve given its L-shape. See a photo at QuickOilDrainValve.com
Any thoughts?
Thanks!
Any thoughts?
Thanks!
My Ride: F10 M5
Model Year: 2013
Any thoughts?
Thanks!
Any thoughts?
Thanks!
As for the drain valve use the open ended side of the wrench.
Hope this helps.
Any thoughts?
Thanks!
Any thoughts?
Thanks!
9mm screw - (5-8 ft-lbs)
11mm screw - (9-12 ft-lbs)
If you want to get real scientific (wear a white lab coat like a NASA scientist) use a deeper socket or crow's foot wrench on a very small torque wrench (for crow's foot you have to calculate offset and adjust torque).
But IMHO that is making a mountain out of a mole hill. As an old Italian mechanic I would frequent used to say "Tight, but nota tooa tight".
A cheap set of crow's feet from HFT - http://www.harborfreight.com/7-piece...set-94427.html
2. Fumoto oil drain valve - Assume same as oil drain plug - 10 Nm or 89 in-lb (About 7.5 ft-lb).
Again if it has hex drive surfaces use the crow's foot with calculated offset.
Just use a flare nut wrench on the brake bleeder screws. You can get a 9 x 11 mm flare wrench for about $4 from Cripe Distributing
DavaiLave
08-02-2022 02:16 AM
UltimatePeter
DIY: Do It Yourself
09-28-2015 09:12 AM
spitfire23
05-12-2015 04:23 AM
TexaZ3
05-06-2015 09:54 AM
