High Beam Assist/FLA
#21
I've done all of the above, I can see the FLA in INPA, I can diagnose it. The vin of the module is also changed. I've added $5AC and everything is coded accordingly. My KOMBI version is 9126642 lastly updated 09.11.2007. If I try to update it with DATE V50.2 it gives me the same number, thus I didn't proceed. The FLA sensor is working, the headlights are in auto mode, but the FLA is not working at all.
P.S. When I activate the FLA in the CAPPL and if I try to turn it ON it stays for 1-2 seconds ON and then automatically switches to OFF?
Did you ever find a solution?
#23
My Ride: LCI E61 535D
Model Year: 2009
Engine: M57tu2
I bumped another thread relating to high beam assist. I am going to bump this one, too.
Here is what I have done to my 2008 M5:
Installed correct mirror. Wired to K_CAN_SL and K_CAN_SH.
Changed the vehicle order to include $5AC in both the LMA and CAS.
Coded CCC_APP trace and changed VA_LONGDISTANCELIGHT to aktive.
I can see "high beam assist" in I-drive. But, the actual on/off of the high beam is still not working. What am I missing? Do I need to code the Kombi or something else?
Vman33
03-14-2022 04:43 AM
umnitza
09-02-2015 11:28 AM
spediegunz
08-30-2015 09:43 AM
