E61 Steering wheel heater retrofit ?
#21
My Ride: 535D lci E61
i found in one photo on steering wheel for sale, there are one 2 pin connector and one 1 pin connector, i hope : Heater element had connection via 1 pin and earth and temp sensor is via 2 pins.
i have only heater elenet from e65, not wheel...
i think it must have minimum of 3 wires because NEG, POS, Sensor ,Sensor.
FYI, its very easy to put down airbag.... just put flat acrewdriver with steering wheet straight in to a small hole towardr direct up direction.
#23
My Ride: 530e Alpine White
Model Year: 2017
@Hyri: Great job. Would love to see the finished picture. How the e65 steering looks on E60 interior. Would you mind sharing some pics of your accomplishment.
#24
noone should helped me with banal question where i need to connect 3 wires.
i have only heater element from e65 which is inside e60 M wheel with 2TB Paddles polstered in to leather and alcantara.
#27
Model Year: 2017
Hi everybody, after years of fun I am parting with my faithful 525i. Hence, I will be taking out all the mods that were done to the car. I have the full SAT kit including shifter+steering, also as the steering is heated I have the switch+coil spring+switch unit steering column for sell. PM me if anybody is interested.
TexaZ3
05-06-2015 09:54 AM
