E61 Steering wheel heater retrofit ?
My Ride: 2004 BMW E60 525dA - Comf. seat, Hi-Fi Logic7, Navi prof, carphone prof, seat ventilation, Dynamic Drive, Active steering ++ Retrofits:- 9x20 & 10x20 BMW Style 101 w/ 255/30 ZR20 and 305/25 ZR20- 35/35 H&R sport springs - M-sport package- M5 trunk li
How did you fix this?
Here my the DIY in German (i translate later)
DIY - Nachrüstung Lenkradheizung LCI :
Benötigt wird an Neuteilen :
- Lenkrad mit Heizfunktion
- Wickelfederkassette
- Schaltzentrum Lenksäule SZL
- Lenkstockabdeckung ( ohne elekrtrische Lenksäulenverstellung)
- Schalter Lenkradheizung
Arbeitsschritte :
- Austausch der neu benötigten Teile
- Codieung neuer FA mit $ 248 LENKRADHEIZUNG
- ggf. ersetzten der VIN im SZL
- Kalibrierung des Lenkwinkelsensors
Arbeitsschritte :
My Ride: 2004 E61 530D - Dynamic Drive - Active Front Steering Sport Seats - Voice Control - Head Up Display - Nav Pro - Bluetooth - Panoramic roof - Front/rear heated seats
Hello Bert,
Could you include some pricing indications as well in the translated version?
Many thanks!
Many thanks!
Need of new parts will be:
- steering wheel with integrated heating system
- Rotary coupler
- SZL Switch center steering column
- steering column cover (only without electric steering column adjustment)
- heater switch
Steps:
- exchange of new parts required
- Coding new FA with $ 248 LENKRADHEIZUNG
- possibly replacing the orig. VIN in the SZL
- calibration of the steering angle sensor
Prices and Partnumbers look on the online ETK by your model.
The parts are expensive ~1000 ? ... look for used parts .
- Rotary coupler
- heater switch
Steps:
My Ride: 530e Alpine White
Model Year: 2017
I think the DIY is already posted here. Other than replacing the parts and coding the car do I need to do any addtional wiring? My car is 525i MY 03/07 LCI. I have electronic steering adjustment.
My Ride: BMW e60 525Da LCI White, DPF out, Front grill black, Shadow line, license plate super bright led, interior white leds;
i'm interesed too with this retrofit, anyone know how to do? details more, i have m5 steering wheel heated, and i see that on my lci 525 car i have connections for heater but i can't know how to do
Model Year: 2017
I am almost ready to take up this retrofit, szl, coil spring and switch already at hand, steering is on the way. From TIS I found the instruction to remove the coil spring, but cannot find the procedure to remove the SZL, any help is appreciated, also how to do the calibration of the steering angle sensor? I have used INPA to read error memory and used ncsexpert to code retrofit.
