DIY ZF 6HP19Z Transmission Drain & Refill
#343
My Ride: 530i
Engine: N52
I ran my finger along the pan seal 1st to ensure it was seated properly, and then again with tranny fluid to moisten the seal before installing it.
#344
Can someone help me how to read TFT on this interface I am seeing in INPA? Everyone else seems to see windows with progress bars rather than numbers like me. My INPA version is 5.0.6
thanks
thanks
#345
My Ride: 05 545i 6MT
I did the same on my buddy's 2008 E60 528i w/ 6 Speed Auto (110k miles).
I flushed the fluid w/ Valvoline Maxlife ATF(via transmission cooler line. Buy the tool to remove the cooler line!) until the fluid came out RED clean.
BMW Transmission line tool:
I also changed the bulkhead connector seal, transmission filter and reset transmission adaptation and filled at correct fluid temperature.
Bulkhead connector seal:
In the beginning, it shifted really hard, but after couple of days drive cycle, it now shifts very smooth (but fast) than old ZF fluid.
This Maxlife is full synthetic and should last longer than the ZF.
I saved Valvoline's response listing this transmission fluid is approved for use in BMW LT71141, LA2634, M-1375.4, ATF 3.0.
Now the car has been running w/ Valvoline Maxlife ATF for about 15k miles w/o issue,
#346
In the beginning, it shifted really hard, but after 1 week, it now shifts very smooth (but fast) than old ZF fluid.
thanks
#347
#348
this may sound like a very dumb question but I have a 2004 525i & was wondering if theres any way for me to check the fluid level in my transmission besides draining it? I was also wondering where it is that I add tranny fluid on this vehicle?
#350
My Ride: Jet Black 2006 525i:
Cold Weather Package, HUD, Navigation System, Adaptive Xenon Headlights, Premium Sound System.
Im about to attempt this service myself on my car. Im just over 150k miles. I watched all the old Bav Auto DIY videos before realizing the E60s have a different transmission, and have since watched multiple videos on E60 transmission fluid and filter changes. The only thing I'm unclear on is, do we have a separate pan gasket like older model BMWs? The pan I bought looks like it has one built in.
