DIY LCI tail light retrofit (cheaper method) Verison II
Old 08-27-2013, 05:39 AM
  #71
pluto2013's Avatar
My Ride: E60
Thnx Bimma328 i'm very curious
Old 09-01-2013, 11:38 PM
  #72
pluto2013's Avatar
My Ride: E60
any news bimma328?
Old 09-03-2013, 03:21 PM
  #73
bimma328's Avatar
yes it works ok for now, im having strobing also which sucks in the daytime because the fog light and rods are like a christmas tree, i just finished modifying the module over the weekend, i have all the pics on my iphone, im running the tests tonight , i will keep you posted
Old 09-04-2013, 07:42 PM
  #74
bimma328's Avatar
still getting strobing when the light switch is off, maybe its because im using an LED bulb for the fog light, i might have to double the 20ohm resistor since im using 1 bulb only and not 2 like the brakes are suppose to, also i can stop the strobing by having my led rods on at all time, i think i will modify something inside the LM1 module, ill post the results
Old 06-12-2016, 03:54 AM
  #75
Michael Choi's Avatar
My Ride: E60 M5
My car is pre LCI E60 M5 car which has retrofitted to LCI tail light before. Today I installed the ricky effect board. However, the 5 strings didn't turn on when I turn on the light. Instead of this the outer brake light turn on all the time.
Anyone know what happened?
socale39
09-05-2023 08:30 AM
Beemer
33
01-14-2019 05:13 AM
Koqui79
05-24-2015 06:47 PM
rizwan1377
04-05-2015 05:22 PM
andymax
03-13-2015 10:51 AM
Quick Reply: DIY LCI tail light retrofit (cheaper method) Verison II
