Sirius Satellite Radio Delete
Old 01-14-2017, 08:07 PM
westsidebalto's Avatar
My Ride: Sold: 545i, sport package, cold weather, 6MT
Engine: N62
Default Sirius Satellite Radio Delete
Since my Sirius unit decided to stop working, I decided I wanted to permanently delete/remove my unit. I've long suspected it for being responsible for "waking" the car when it should be in "sleep" mode. Since it runs every time the car is awoken, removing it should eliminate some battery drain. Also, since I have the iPod option in the glove box and I don't drive a whole lot, I have little use for Sirius.
Step 1: In the trunk, remove the rear driver's side panel in front of the taillight. If you don't know what this is, it's the mirror image panel as the passenger side one over the battery.
Step 2: Use an 8mm socket to remove the three bolts holding the Sirius bracket to the vehicle.
Step 3: Unplug the antenna connector (two wires). This seemed to just pull right out
Step 4: Unplug the MOST/power connector. Doing so will mean there is a break in the MOST fiber optic system, thus allowing anything after Sirius in the system to not function, which for me includes the iPod connector, which takes us to:
Step 5: Remove the power connector from the side of the MOST/power harness. There is a small clip on the side, and the power connector slides out the side of the harness, not the rear as you might think.
Step 6: Remove the MOST connector housing from the MOST/power harness. This pulls out the rear of the harness.
Step 7: Remove the MOST cables from the MOST connector housing and reinstall the MOST cables into the new MOST connector housing (Part #61136917978)
Step 8: Install the MOST connector housing and cables into the fiber optic loop (or Fiber Optic System Jumper as it's also known) (Part #61136917541)
Step 9: Tuck cables away and reinstall trim. You're done!
Once the unit is uninstalled, the "SAT" option in iDrive should be grayed out and non-selectable. Using the steering wheel button to advance the input type should skip right over SAT from AM to CD.
Old 05-14-2021, 09:46 AM
aNo94's Avatar
This is an old thread but I want to comment so I can refer back to it. My SAT module died and I need to bypass it so this post is very helpful.
Old 05-14-2021, 02:28 PM
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Why don't you just get one form out of the junk yard or on eBay if you actually use it.
Old 05-14-2021, 05:41 PM
aNo94's Avatar
I'll do that eventually. I ordered a bypass loop that will be in tomorrow...i'm tired of driving around without any audio whatsoever. I'd have to wait a week or more to get a replacement module off of ebay...and then I have to hope that the used part actually works.
Old 05-14-2021, 10:00 PM
Model Year: 05 530i
Engine: 3.0 M54
Ok let us know how it goes
igoraraujo
04-23-2010 09:07 AM
jrm21
09-13-2007 02:58 PM
tedmundson
09-13-2007 02:52 PM
Faze
10-12-2004 02:11 PM
fmusbmw
04-11-2004 04:13 PM
Quick Reply: Sirius Satellite Radio Delete
