DIY: 2005 530i (M54 engine) Spark Plug Change
My Ride: BMW E60 530i , Silver with leather Air Con iDrive 17" Breyton Rims with Dunlop Sp Sport tyres (M-Tech Bodykit and rims WANTED)
Alfa Romeo 147 TS1.6 , Black with Air Con 17" Multi Spoke alloys with Bridgestone RE040 tyres
Toyota MR-S 1.8 VVTI , Lagoon Blue with Red leather Air Con 15" standard alloys with Toyo tyres
Toyota Celica 1.8 VVTI, Lagoon Blue, Air Con, 16" Standard alloys with Kuhmo KU31, EBC Green Stuff
Very detailed write up!
Nice for sharing
Nice for sharing
Model Year: 2010
Torque specifications for unlubricated spark plugs (no oil, grease etc on thread):
Standard Engines: Thread M14 x 1.25
31 +/-2 Nm
23 +/- 1.5 ft/lb
http://www.dtbmw.com/tips/SparkPlugChart.pdf
All current NGK Spark Plugs are manufactured with special shell plating on the metal body that does not require Anti-Seize.
31 +/-2 Nm
23 +/- 1.5 ft/lb
My Ride: 2005 530i, Orient Blue, M-tech Front, otherwise stock.
31 +/-2 Nm
23 +/- 1.5 ft/lb
31 +/-2 Nm
23 +/- 1.5 ft/lb
Thanks for the info!
My Ride: 2007 Mercedes CLS63 AMG
Designo Graphite with white leather interior
Keyless Go, Heated/Ventilated seats, Parktronic
Very nice and detailed DIY! Great post.
Quick question though, I didn't see anything mentioned about measuring the spark plug gap. Did you measure the gap and adjust or just install them as is out of the box?
Thanks, Lawrence!
I just followed your DIY step-by-step and replaced the spark plugs in my '05 525i. Your DIY was extremely helpful to someone like myself who has never done any sort of engine work short of changing fluids, much less spark plugs. I opted to replace the spark plugs with OE Bosch ($6-7 each shipped from autoanything.com) since I've read about reduced longevity in some of the higher performance iridium plugs. I noticed that a couple of the 13mm plastic bolts must've already been broken by the mechanic at the dealer since they were missing. Oh well, everything is still held in place tightly. I replaced mine at 60,000 miles as well...the plugs looked very similar to the pics you posted. I haven't noticed any sort of performance gains yet, but we'll see if my fuel economy increases 1-2 mpg. The whole project took about 70 minutes (3 beers) but I was really putzing around and taking my time.
thanks again!
thanks again!
