Changing original steering wheel to sport
Old 06-10-2016, 02:37 AM
  #71
STR8's Avatar
My Ride: '03 530
does anybody know if 2004 airbag will fit and work with 2008 steering wheel??
without changing mounting plate?
Old 08-24-2016, 03:43 AM
  #72
Arvidszon's Avatar
My Ride: BMW e60 530i
Hello everyone! I've had my Bmw e60 for a year now and I've always wanted to upgrade to the sport steeringwheel as it looks so much better than the standard "Diamond".
I've read this topic from top to bottom a couple times now, but there is one thing I'm still not sure about.
For starters, my car is a pre LCI. And I've bought one wheel that is pre.. And one that is LCI just for the airbag and the backplate which from what I understand goes together.
Was thinking of just swapping the airbag into the pre. one, but I didn't get the airbag wiring with the airbag itself.. Is that needed or can I use the wiring from the wheel that is in fact still in the car?
If you look at the images below, is the wire which has been cut on the airbag supposed to go to that point on the backplate in the steering wheel, or is it supposed to go into the connector among the airbag wires? If so what is the point of the connector on the backplate?
Old 08-24-2016, 02:12 PM
  #73
Kewill0360's Avatar
My Ride: 535XI
Engine: N54
Hope this help.
Old 08-24-2016, 07:02 PM
  #74
Arvidszon's Avatar
Thanks, but it's not helping me right now though. :-/
I'm wondering if it's possible to use the airbag wiring from my original 2003 steering wheel, locate which wires are positive and negative for the horn and then split them into two connectors instead of one.
Wouldn't positive of these two be rightfully connected to that marked point on the airbag then and negative to the backplate? Other way around it would honk all the time? :-)
Old 08-12-2023, 02:18 PM
  #75
deadrabbits's Avatar
My Ride: 2005 525i (manual swapped)
Just completed this mod. My car is an 11/11/04 build date 525i, the steering wheel is from a 2008 528i. The steering wheel was sourced from a junkyard, I paid $15 for the wheel and $50 for the airbag.
Old 08-12-2023, 02:43 PM
  #76
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
This is what I want to do but just too lazy to do. My current steering wheel is peeling and I want to replace it or wrap it. Both take about the same amount of time to do.
Old 08-12-2023, 04:08 PM
  #77
I don't blame you lol, this took all day and I never want to do it again.
Kasmo
05-07-2019 03:30 AM
jckrauskopf
12-22-2003 01:39 PM
ISUK
08-20-2003 08:55 PM
08-12-2003 11:41 AM
06-17-2003 09:38 PM
Quick Reply: Changing original steering wheel to sport
