Angel Eye one eye is brighter?
Old 01-14-2009, 08:06 PM
schanE60's Avatar
I just installed MyCarr AngelEye. I notice on the driver side, the eye around the low beam is brighter than the high beam eye.
The passenger side, both eyes seems to have the same brightness.
On the driver side, when I tilt the bulb a bit i notice I can make the two eyes have the same brightness, but I cant secure it so it stays like that..
Any input people?? Thanks
Old 01-14-2009, 08:08 PM
schulrog's Avatar
it's not seated properly in the housing.
Old 01-14-2009, 08:09 PM
Gene's Avatar
sounds like the bulb is not inserted properly...
Old 01-14-2009, 08:16 PM
schanE60's Avatar
Hmm.. I'll try secure it more in the housing, I'm quite sure its as flush as possible though. All three "tabs" are securely in place and in the right order (One square, two tilted). I even tried swapping bulbs, but the same side still has one eye brighter.
derooster
09-22-2016 07:30 AM
bestofthebest
03-28-2016 02:47 PM
umnitza
11-03-2015 02:58 PM
09-13-2015 05:49 PM
Quick Reply: Angel Eye one eye is brighter?
