Brake fluid change DIY
Old 05-09-2013, 04:34 PM
  #91
hatemramadan's Avatar
My Ride: BMW 530i 2007, 535i 2013, 318i 2004
Thanks very much for the effort you have spent in showing us how this is done.
Old 05-10-2013, 05:13 PM
  #92
proplan's Avatar
My Ride: 2004 545i
This is an awesome DIY! Thanks, will reference this later when I need to do this!
Old 06-23-2013, 09:53 PM
  #93
Mj888's Avatar
My Ride: 528I
Thanks!!!
Old 08-22-2013, 02:24 PM
  #94
gcalo's Avatar
My Ride: 530i
Engine: N52
Great write up.
The whole trick to bleeding brakes is patience.
Just make sure when you are done the pedal is as hard as a rock or you'll experience the effects of air in the system.
I generally don't use pressure systems.
I first vacuum out the master cylinder with my air powered bleeder assem. Then I fill with new fluid. This gets out any bad effects from the resevoir and prevents them from traveling in the system during the process.
Takes more of the old fluid out faster and makes the process easier.
I then regularly fill the M/C as I bleed each caliper.
I have my bride pump the pedal so I am sure I have bled out everything on each caliper.
Either way is fine though.
Old 09-16-2014, 07:11 AM
  #95
vascool's Avatar
Bavauto says I need a $20+ adapter for a 2005 545... from the pictures it looks like I should be ok with the stock twist one.. anyone tried this?
This adapter allows you to use your Bavarian Autosport Brake Bleeder on autos other than BMWs. Works on reservoirs with filler openings up to 90 mm in diameter. Has quick connect fitting for use with PB03 brake bleeder. Part Number Description Price Qty. ALB30583 Multi - Vehicle Adapter for Bavarian Autosport Brake Bleeder
part : ALB30583 (which does state that this is for cars other than BMW...)
Old 09-23-2014, 11:12 AM
  #96
txag_530i's Avatar
Skip BavAuto and buy the Motive brand. Motive is the OEM for BavAuto.
Search Amazon for ASIN B0002KM5L0
It will cost $50 delivered to your door.
Amazon.com: Motive Products Power Bleeder Adapters to fit most European car models: Automotive Amazon.com: Motive Products Power Bleeder Adapters to fit most European car models: Automotive
Old 08-30-2016, 04:29 PM
  #97
cmyachtie's Avatar
My Ride: 2004 545i+BT+AUX+Coding
Engine: N62
That's what I have used twice now, works like a charm, also for,those wondering about getting air in the system with this unit it does not!!
I forgot to refill the master and just attached the bleeder with two Qts of new fluid after I sucked out the old fluid, also forgot to pre pressurize it and just pumped it to 20lbs and bled all 4 calipers and still had a qrt in the bleeder when finished, pedal hard as a rock....
Old 11-10-2020, 06:29 AM
  #98
cmyachtie's Avatar
Engine: N62
An update that may help someone, having used the pressure bleeder now every 2 yrs and not having noticed any color change in the fluid, and was using one litre or slightly more pentosin dot 4 lv. However this time I somehow got air in the system as I just sucked out old fluid from the reservoir and added new and then just pressurized the system and bled all 4 wheels and replenished new fluid once in between to avoid getting air in system. Never did use BMW DIAGNOSTIC SYSTEM to do DSC flush till yesterday as it was this time necessary due to air intrusion. And did finally noticed difference in colour coming out during the INPA bleeding process of the DSC. (Likely due to it having been there for at least 8 yrs or more). Also doing this flush as per the INPA and TIS described instructions posted above in some previous post, you will need to have 2 litres on hand just to be on the safe side plus put all that in your power bleeder! Am assuming the same goes if you’re used DIS or any other program.
ripley
DIY: Do It Yourself
03-12-2024 01:01 PM
chris f
DIY: Do It Yourself
09-21-2009 12:57 AM
pinguhk
15
08-19-2008 06:32 AM
beaker
08-10-2008 08:31 PM
andy545
07-31-2007 05:19 AM
Quick Reply: Brake fluid change DIY
