e60 n52 buring lean
e60 n52 buring lean
Hey Guys
I have a 2006 525i N52 engine
I've had this CEL since last winter saying both bank 1 & 2 are burning lean
when it first started the CEL would come on when its cold (below 0c) then it would go off when the temperature goes above 10c but now its on permanently.
I did some research apparently there is a Vapor Canister Purge Valve or Vapor Canister under the throttle body that needs replacing.
Can someone point me the right part number and what to do here.
Your help is greatly appreciated.
I had this same issue and I ended changing my air filter. There also was a crack in the intake assembly that I patched up. As soon as I turned the car on the CEL turned off
5fanatic
04-27-2015 04:50 PM
