HELP: Brake Dust Woes
Old 01-26-2020, 03:43 PM
donpb's Avatar
My Ride: '06 530i N52
Question HELP: Brake Dust Woes
I need help with keeping brake dust off my wheels especially the fronts. I've tried lots of things including Wheel Wax but to no avail. Can someone offer suggestions please? Thanks in advance.
Old 01-26-2020, 04:07 PM
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Change the brakes to ceramic. Either way, you will still have brake dust just not as much.
Old 01-26-2020, 04:48 PM
Administrator
JayArras's Avatar
My Ride: 530xi
Engine: N52
Yeah, most of the treatments I've seen only last about two weeks and then you have to keep reapplying. Do yourself a favor and change out your pads to ceramic. I prefer Akebono. If your pads still have life, live with the dust until such time when can swap them out.
There are lots of discussions here about the pros and cons of ceramic pads, but I think the consensus favors them.
Old 01-26-2020, 05:50 PM
spazzz's Avatar
My Ride: 2008 535xi
Model Year: XHP&MHD
Cleaning them more often is your best choice.
Akebono pads are the way to remedy this as mentioned. I have them but also pull the wheels off and use one of the ceramic coatings.
Clean with Iron-X, rinse, wheel cleaner, rinse, soap, rinse, polish, wipe down with paint prep(or 15% isopropyl alcohol/water mix) and finally coat.
I use CarPro CQuartz UK3 just because I always have some. It works great.
The dust doesn't collect as willingly and pretty much blasts off with water. Although you should clean them with your car soap and a set of wheel brushes of your choice.
The barrels are very important to keep clean besides the faces.You dont want the dreaded BMW baked brake dust on your wheels.
Old 01-27-2020, 12:29 AM
donpb's Avatar
I was thinking about changing to ceramics but my Indy mechanic says rotors wear faster with ceramics.
What has your personal experience been with ceramics? Is there any noticeably excessive rotor wear over metallics?
Old 01-27-2020, 01:37 PM
spazzz's Avatar
My Ride: 2008 535xi
Model Year: XHP&MHD
I am not a brake pad burner so I don't have a problem.
I almost never have to hit the brakes hard. I predict and coast a lot.
I have heard that before about ceramics but never really noticed any excessive rotor wear.
This was the first google after searching do ceramic brake pads wear rotor quicker
from Tire Rack
These pads use ceramic compounds and copper fibers in place of the semi-metallic pad's steel fibers. This allows the ceramic pads to handle high brake temperatures with less heat fade, provide faster recovery after the stop, and generate less dust and wear on both the pads and rotors.
someone is smoking the ganja
sixgun95
Detailing Forum
11-15-2006 06:03 AM
sixgun95
Detailing Forum
17
06-29-2005 05:12 PM
ChaseCIA
06-25-2005 02:07 PM
Presley348
12-01-2004 02:11 AM
Presley348
Detailing Forum
10-17-2004 01:33 PM
Quick Reply: HELP: Brake Dust Woes
