Bluetooth cannot be activated in iDrive 05' E61
Old 01-14-2013, 03:52 PM
pjinca's Avatar
Originally Posted by Supertramp
Thanks for the advice, will look in the trunk and see what it says, or I will also go the route of a TCU unit, as ususal BMW would most likely charge the earth which they are famouse for ....
HAHAHA, yep, like I said, they wanted to charge me $1400 at the dealer to replace and code my TCU. I found a TCU on eBay for $98 used, with a 6 month warranty (long past now) and got it installed and coded for ~$100, not bad. There's a reason they call them "stealers"
Old 03-15-2013, 04:03 PM
kkrazykool's Avatar
My Ride: 530d Sport Touring, Titanium Silver, HiFi Loudspeaker system, Heated Front Seats, Tracker Retrieve, Media Package, Black Dakota Leather & Steptronic Transmission
Originally Posted by Rain
Any update on the bluetooth issue you had? Did the dealer find the problem?
The stealer in maidenhead refused to accept that they had performed any action but did tell the mulf module connector one pin was loose and they would charge 700quid to fix it because they were not trained in repairing pins.
So finally figured that the ulf module was dead, you can tell because, there is no red lights seen coming from it. I unclipped all the connectors and unscrew the torx screws. Looked at the pins and one of them first column, second row was loose and after looking at the pcd found it was disconnected. I used a soldering iron to drop some solder to join the pin to the pcs an hey presto the dead ulf module now works!
Old 07-28-2015, 03:42 PM
boozooface's Avatar
My Ride: 2006 530i with Bluetooth assist, Xenon headlights, leather upholstery, heated seats and comfort package
Is this still live? Im having the same issue with "Mobile phone not installed" and my car definitely has bluetooth (I used it), but now its gone.
Can anyone help me?
socale39
09-05-2023 08:30 AM
squints2c
10-06-2022 03:33 PM
Awest91
09-17-2022 11:05 PM
passtheword1
03-13-2015 03:17 AM
08-12-2003 11:41 AM
Quick Reply: Bluetooth cannot be activated in iDrive 05' E61
