03/04 to 08/04 BLUETOOTH CAN BE DONE WITH CODING! NO $$&
Old 06-02-2015, 05:53 PM
  #101
ras545i's Avatar
My Ride: Black, sport pkg LA style rims, sun shade on rear passengers and rear glass, 6disc changer,
Default bluetooth??
I have an 04 545i vin: B110123
It has the voice command, navigation, and phone cradle...
Im trying to see if I need to purchase additional devices or this code option can get me going.
Old 10-23-2015, 02:05 PM
  #102
rmatrafajlo's Avatar
My Ride: 04 bmw 530i vin Wbanan73574b810798
I am in great need for some help e60 2004 and hooked in aux jack and get a code 1000 and also can not get bluetooth to work
Old 12-27-2015, 11:08 PM
  #103
jchabot's Avatar
My Ride: BMW 545i 2004, Chevy Camaro '67
Originally Posted by svre46
So I did this and Bluetooth works. Voice command, pairing, contacts..ect all work fine. I have the original TCU and a retrofitted CIC
2 issues.
1) SOS error now. Might have an idea of a few TCU settings to change but need more time to mess with it. I even took it out of the VO and recoded the TCU. Still there regardless. FIXED
2) Microphone does not work when making calls. Works to dial but no one can hear me in a call. Before anyone says it the line below is not on my TCU trace file.
"USED_MICROPHONES wert_01 (1 microphone) or wert_02 (2 microphones)"
Any ideas?
Got the same microphone problem here, Have you fixed it? Thanks!
Old 12-27-2015, 11:34 PM
  #104
jchabot's Avatar
On my 2004 545i I did successfully enabled the bluettooth option. I can pair my iPhone 5, make and receive calls, access to my phonebook but the callers can't ear me... Tried both microphones options: "USED_MICROPHONES wert_01 (1 microphone) or wert_02 (2 microphones)" but none helped. Anyone experienced and fixed that issue? Thanks!
Old 02-23-2016, 10:04 AM
  #105
Pasha Hlushenkov's Avatar
My Ride: e61 535d, 2004
Hi guys, im new to the club and i need help.
I have a Bluetooth factory installed in my bmw e61 2004. The MULF module has gone and I bought another one second hand and now i cant pair a phone to it. I've been told it's because it was previously and coded to a different VIN. How can i code it to my car now? Any knows?
Sorry for my English and thanks in advance
Old 04-29-2016, 06:31 AM
  #106
tivinps's Avatar
My Ride: 2004 545i
Model Year: E60 2004
Engine: 545i / N62
Hi
I search my car VIN (2004 545i) it said:
639* COMPLETE PREP. CELLULAR PHONE USA/CDN
Prod. date* 2004-06-21*
But when I go to the Communication Menu its states:
contact BMW dealer and no service is enable.
From time to time the signal goes low and bip sound goes on, like out of range.
Can I active Bluetooth or do I need something first? Any suggestions or help?
Old 04-15-2017, 07:20 PM
  #107
Daniel Jose Rivera's Avatar
My Ride: 04 bmw 525i e60
Default I need Help!!!!
Can you please help me activate Bluetooth on my e60? My build date is 7/04 and I'm going crazy trying to get Bluetooth activated. I will greatly appreciate it
Originally Posted by brendinernst
So I have been told by every dealer that the service bulletin that says that cars produced between 03/04 thru 08/04 cannot have bluetooth until the car has the proper TCU put in. This is a LIE I have been coding with NCSExpert for a while now and I dove into the bluetooth coding last night and I am making calls through my car today! So for anyone that has been told "no" I am proof that that is a lie. I am in OHIO and if you would like me to activate your bluetooth PM me.
Old 12-20-2018, 02:20 PM
  #108
ron_of_orange's Avatar
My Ride: 2004 BMW E60 545i
Engine: N62
Cool 2004 e60 First Steps?
My TCU plastic card say's many things and leads me to think it might be useable. My vehicle production date is 2004/05, a Davis report for my car also offers the following: TSU ESN / TCU IMEI the sticker below includes ,BT, PK 1546 and matches the attached pic's posted here (below).Davis report for my car lists the following dealer options codes as follows: 0605, 0609, 0610, 0620, and 0639. I'm not offering the descriptions, thinking these should be familiar to others based on my review of this these threads. The 0609 code is the desired code for Bluetooth. Added to this brief description is the vehicle has a drop-in support adapter which my research would be a "CPT9000" the bluetooth pairing device normally connected here. This is where I'm currently requiring more information. I see and have read about the need to update the "CODING" using NCSexpert. I dont have this program... But I do have a laptop computer running INPA, edibas, DIS, TIS, on Windows XP and some other software that I used on my resently sold 1999 E39, 528i. So the first question I feel might be: Do I need a software update for INPA,? other updates for the NCS EXpert are obviously required.. ( I don't have this program) So what version do I need might be a good question. MY first steps are requesting assistant and feedback based on the given information furnished. Being that this is 2019 almost...and current sources have or may soon become more difficult or outdated to access i'm hoping this isn't going to be dead_end street. MY car is low mileage survivor and it appears it was well care for except for bluetooth capabilities. So 2019 might be a good time to re-try some newer devices. Bluetooth capable phones are a nice thing but not really necessary if all you really need is the ability to call BMW Assistwhich my vehilcle has the software already based on the option code 0605. And I have NAV code 0609. So my iDRIVE (center on dash Display) doesn't present a AUX choice which I think hopefully would be a easy fix without any wiring changes ...I have a AM/FM Radio and CD changer. All parties are welcome.
ron_of_orange
so,Calif
12/20/2018
Old 03-06-2020, 12:32 PM
  #109
Leon Naidoo's Avatar
My Ride: E60 530D 2006
Default Leon
I have a 06 530d. Bluetooth is not working and steering, I just bought the car, so I don't no if it was working. The TCU DOSNT SAY BLUETOOTH
CAN IT BE CODED
Old 03-06-2020, 04:00 PM
  #110
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
If you get the Bluetooth TCU it can be coded
Quick Reply: 03/04 to 08/04 BLUETOOTH CAN BE DONE WITH CODING! NO $$&
