ModBargains | BSH Competition Oil Catch Can - FREE SHIPPING
My Ride: E30 325e & E46 ZHP Vert
ModBargains is your Largest Stocking Dealer for the BSH Competition Oil Catch Can for your N54!
*$233.95 with FREE SHIPPING*
ModBargains is proud to introduce the Competition N54 Oil Catch Can by BSH. Adding the BSH Catch Can is one of the simplest ways to increase the performance and longevity of your twin turbo engine. The N54 specific Oil Catch Can features an important layer of aluminum mesh baffling to aid in the separation of oil and air upon entering the catch can. BSH's Competition Oil Catch Can is a must for anyone running higher boost on their 135i/335i/535i or for anyone looking to preserve the longevity of their engine.
Includes:
Applications
Why Should I Get an Oil Catch Can?
The main reason to add the BSH Oil Catch Can to your N54 engine is the reduction/elimination of blow-by. Blow-by is caused when a combustion in the engine forces fuel, air, and moisture past the piston rings and into the crankcase. From there, the blow-by is released by the crank case vents and back into the intake pipe. This occurs on all engines, but is worse on turbo engines due to the stronger combustion. If nothing is done, this excess ?gunk? will build up in the valvetrain, turbo, intercooler, and intercooler piping.
Why is this bad for my N54 Engine?
The BSH Competition Catch Can collects the blow-by and ensures you a clean and healthy N54 engine. This a great investment to increase the life and efficiency of your N54 twin-turbo equipped BMW.
For orders placed online put KEVIN in the CUSTOMER COMMENTS section or give me a call at 714-582-3330 ext 8009
Includes:
- N54 specific 3" recirculation Catch Can
- Billet dip stick
- Laser cut mounting bracket
- Outlet PCV adapter
- Inlet PCV adapter
- 10 push lock line
- All hardware necessary for installation
Applications
- 2008+ 135i
- 2007+ 335i
- 2008+ 535i
- 2008+ X6 35i
- 2009+ Z4 35i
- Blow-by coats the intercooler piping and fins which reduces the cooling efficiency
- Blow-by buildup in the intake pipe can cause disruptions in airflow
- Blow-by buildup in the turbo diminishes the life and efficiency of the turbo
- Blow-by can seep into couplers and boost tubes causing them to pop off during high boost
chadillac2000
42
09-13-2017 11:15 AM
kurtb23
04-22-2015 04:30 PM
DetailersDomain
Detailing Forum
03-24-2015 05:25 AM
